I’m just patiently waiting for AFe to release their non oiled replacement filter. I have used it in multiple vehicles for years. No oil, easy clean, flows better than stock and many aftermarket and did I mention no oil??
Is this what you are looking for?I’m just patiently waiting for AFe to release their non oiled replacement filter. I have used it in multiple vehicles for years. No oil, easy clean, flows better than stock and many aftermarket and did I mention no oil??
pre order.Is this what you are looking for?
https://www.lethalperformance.com/a...rd-bronco-l4-2-3l-t-v6-2-7l-tt-10-10401d.html
They require more maintenance than a dry filter, and can let the oil or particles through if not cared for properly. They can also gunk up your MAF if you are too heavy handed with the filter oil.Forgive my ignorance, why go dry filter over a typical K&N?
But if they are cared for properly when new they can keep more debris from passing through.
You'll still need to replace an oiled filter eventually and for the cost/time of maintaining it dry is a cheaper easier option.
The Roush has a nice benefit of the inspection window and a pre-filter sock. I would give it a hard look if I ever changed the intake.We installed the Roush intake on our Bronco. They're very easy to install and fit great. We didn't do any back to back testing with it but our truck is tuned and see's more boost than stock so I believe we did benefit from it. We have plenty of the Roush intakes in stock so feel free to give us a shout if there's anything we can help you with.
https://www.lethalperformance.com/r...ir-intake-kit-2021-ford-bronco-2-7l-2-3l.html
Lol yeah maybe that dual catch can is available maybe in three years. Their products take forever to release. They should spend less time on blog posts/ pictures and more time on actually releasing products. If I get a CAI I'll go with k&nmishimoto making one.
https://www.bronco6g.com/forum/threads/mishimotos-performance-intake-r-d-thread.38691/
Edit grab the wrong one this on for 2.7
https://www.bronco6g.com/forum/threads/mishimotos-performance-intake-r-d-thread.38690/
i get your point but... The dual catch can been out for sometime.Lol yeah maybe that dual catch can is available maybe in three years. Their products take forever to release. They should spend less time on blog posts/ pictures and more time on actually releasing products. If I get a CAI I'll go with k&n
I have had them on 4 different vehicles 2010 F-150 5.4, 2017 Fusion Sport 2.7 twin turbo, 2013 Focus ST 2.0 turbo and 2013 Focus 4 cylinder naturally aspirated.I always wonder if these CAI increase mpg and HP so easily, why don’t the manufacturers make them standard equipment? Sure would be a selling point to claim additional mpg and HP at a negligible cost. BTW, if you do opt to go with a CAI don‘t go with one that claims it doesn’t require a tune. These units always throw codes after install.
Never threw a code on my jk.I always wonder if these CAI increase mpg and HP so easily, why don’t the manufacturers make them standard equipment? Sure would be a selling point to claim additional mpg and HP at a negligible cost. BTW, if you do opt to go with a CAI don‘t go with one that claims it doesn’t require a tune. These units always throw codes after install.
My understanding is that CAIs work not so much by taking in colder, denser air but from having improved airflow. Factory designed air filter systems are designed to be quiet, they baffle as much induction noise as possible and in so doing they are quite restrictive. I added a CAI on an Xterra and it did produce a notable increase in power and improved MPG. It also had a notable increase in engine noise and a very notable increase in annoying filter cleanings. I am no engineer but I would speculate that improved air flow would translate to improved MPG with a turbo engine by reducing the exhaust pressure necessary to spin the turbo but would not translate to much in the way of improved HP.
Have you got these parts installed yet?I order KN intake with AFE charge pipe. The intake will be received within one week while the charge pipe in July. I will install it and I will give you my feedback.
I received the intake. But for the charge pipes I believe it will be shipped by end of July. Still I dont no if I need to install the intercooler. I am afraid that if I install it without tune it will reduce the power.Have you got these parts installed yet?
