LOUD Rotational Metal Scraping Noise @ Rear Passenger Wheel
BigSkyBadlander
Cole
Montana
'06 Honda Element 2023 Bronco Badlands
Hi Guys,
I have a 2023 Badlands 4 Door and it has about 500 miles on it. I am getting a super loud scraping noise from the right rear wheel. Hitting the brakes does not change the sound, increasing speed increases the noise. However, in reverse there is no noise... What could be going on here?
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Have you taken the wheel off to see if you have a rock wedged in there? I assume you've already looked for a foreign object or bent dust cover.
BigSkyBadlander
BigSkyBadlander
Cole
Montana
It got dark and I won't be able to get to it till next week. I am leaving town. Why wouldn't it do this noise in reverse? I did think about both of those things you said. The reverse thing threw me for a loop.
Ogre
James
'23 BD 2dr 7MT CG, '18 Indian Chieftain
Put it on a lift and search for the noise. Good luck.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi Guys,
Good morning! If you send over a DM with your VIN and Ford dealer info, I can look into your noise concern on my end.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Often times a corner of a dust/brake/debris shield will get bent over and make contact with the rotor. Moving in one direction rotates the rotor against the grain, the reverse direction goes with the grain. And in this case, the grain is meant to be representative of however the shield is bent and getting “played like a violin”
Pretty common, hopefully this is all it is
BigSkyBadlander
BigSkyBadlander
Cole
Montana
I verified that it was the rear passenger side making the noise. I pulled the dust cover off and there was no visible damage or debris. I put the dust cover back on and had daylight all around and spun the rotor to listen for a grind and it was seemingly coming from the hub assembly. I bent the dust cover away from the rotor very slightly just in case and drove it. Sound was unchanged. Makes noise going forwards, not backwards.
Ogre
James
I verified that it was the rear passenger side. I pulled the dust cover off and there was no issue. I put the dust cover back on and spun the rotor to listen for a grind and it was coming from the hub assembly. I bent the dust cover away from the rotor very slightly just in case and drove it. Sound was unchanged. Makes noise going forwards, not backwards.
So the noise wasn't there with the dustcover removed? That part was unclear.
A very slight shift of direction the weight shifts could move it away from the rub. An improperly seated bearing is highly unlikely but possible. Let the dealer handle it. Gotta love warranties.
BigSkyBadlander
BigSkyBadlander
Cole
Montana
Oh, I meant I inspected it and found no debris or damage to the dust cover.
I3lackRose
Justin
Ohio
What does the transmission have to do with the right rear wheel making noise?
There is rotational scraping noise issues happing inside many of the 7MT transmissions so was just wondering.
Begster
Boston
22 Bronco
Yep, I have the scraping sound in my 7MT. A noise on the rear wheel is a little far away to be related though.
BigSkyBadlander
BigSkyBadlander
Cole
Montana
I3lackRose
Justin
Ohio
I assumed, did sound like they were pretty confident about the location of the noise but just wanted to throw it out there incase.
