- First Name
- RTR
- Joined
- Sep 23, 2022
- Threads
- 44
- Messages
- 170
- Reaction score
- 740
- Location
- Concord, NC.
- Website
- www.rtrvehicles.com
- Vehicle(s)
- Bronco RTR
- Your Bronco Model
- Raptor
- Thread starter
- #1
The RTR Bronco Roof Rack blends off-road capability and versatility to create the perfect platform for adventure. This Bronco Roof Rack was designed to seamlessly integrate with any 4-door Bronco or Bronco Raptor and is compatible with either hardtop or softtop options, and with a unique design that integrates seamlessly with your your Bronco.
The RTR Roof Rack is constructed from constructed from formed steel plates, 1.75” OD steel tubes, and 30mmx60mm heavy-duty aluminum TSLOT crossbars. The tubular steel is finished with a black powder coat and the TSLOT cross bars are anodized with a black finish. With all of this, the overall height is only increased by 3.625 inches.
The RTR Light Bar is designed and manufactured with consideration of OEM fitment. This light bar is designed to have a tight fit on your Bronco. The RTR light bar is a gusseted steel bar that eliminates any flicker in the light pattern and has a durable, powder-coated finish. This product DOES NOT come with lighting provisions, we recommend these PROJECT X lighting options.
Optional Molle Accessory Panels are available separately for added mounted storage and rigidity. They can be installed on each side of the RTR Bronco Roof Rack and feature numerous mounting locations for all of the accessories that you may need on your next adventure. The RTR Roof Racks integrated TSLOT crossbars allow you to add rooftop tents, cargo boxes, or recreational outdoor equipment. This roof rack has an 800lb static load rating.
The RTR Bronco Roof Rack utilizes factory mounting locations to ensure rigidity and durability, due to this modular hard tops are not removable while the RTR Roof Rack is equipped. Since we already designed the RTR Lightbar to utilize the factory accessory mounting points, our engineering team designed the Roof Rack to seamlessly integrate with the RTR Lightbar and provide your Bronco the reliability and security for the adventures ahead.
For more information, please visit this LINK!
- Fits any 4-door 2021+ Ford Bronco and 2022+ Bronco Raptor
- Compatible with hardtop and soft-top-equipped Broncos
- Direct bolt-on installation
- Constructed from formed steel plate and 1.75” OD steel tubes
- Includes (6) heavy-duty 30mm x 60mm TSLOT cross bars
- Powder-coated steel parts and anodized aluminum crossbars
- Optional PROJECT X lighting options and Molle Accessory Panel
- Durable, powder-coated finishes
- Overall height increased by only 3.625 inches
- Made in the USA
