JediMcMuffin
Tommy
2026 F-150 Tremor 401A
Just got a set of 5 of these. Matte Titianium Gray. Saw some conflicting info re weight. So, weighed them myself. Weight = 28.4 lbs.
Looks great, those are the ones I'll be after eventually. So that is 7lbs lighter than a stock Sasquatch wheel?
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
Yes. But the lighter wheel gives justification to offset the weight savings with a heavier MT 🙃 .
Ford Bronco Ford Performance Method 703 Wheels Weight = 28.4 lbs Luna New Shoes (2)
Mtea
Marty
Idaho
2023 2dr 2.3 Auto, Porsche Cayenne Diesel Platinum
Does anybody have pictures of the 703 Matte Titanium Gray wheels mounted on a cactus gray Bronco? Wondering how it would look.
Ft. Worth Rob
Rob
Ft. Worth
BMW X7, Bronco OBX
I measured my old Sasquatch’s at a hair over 39lbs. They’re heavy AF.
@Beach_Bum love the look, especially the raised red letter tires. I wish I could get those FP center caps for my titanium Method 316’s but mine aren’t hub centric.
Beach_Bum
Ken
St. Augustine, FL
Thanks. I was holding out for the FP "faux locking hub" caps. Gives it a little old-school nod. The early batch from FP still had the Method center cap.
I knew the Sasquatch wheel was heavy. I thought they were 36lbs. 39lbs is worse, yet.
I love the X3's. The red letters are quite distinctive. They are a heavy tire, though. Still worth it.
JediMcMuffin
Tommy
Oh wow, so 13lbs a wheel almost full offsets the weight I gained when going to Falken Wildpeak RT01s. I think these wheels just moved up to the top of my priority list.
jehines3
Easton, MD
Lexus RX350L, Chevrolet Silverado, Lincoln MKC
These were my first choice wheel but unobtainable when I was ready, so I pivoted to RTR Evo. Pulling this much weight from wheels is a real game changer when doing five tire rotation and other wheel off work. The RTR’s came in under 24 lbs. I may eventually pivot back to these wheels when I go to 35’s.
Dan00Hawk
Plainfield, IL
2023 Bronco
Going to a lighter wheel always helps me justify a new wheel purchase as being "not just for looks". Improvements to handling, braking, and acceleration may be difficult to quantify, but it's a certainly a better move than going to something heavier. My 17x8 TK15 Sport Terrains come in at 23 lbs.
timbits588
WNY
2017 Expedition EL Limited, 2023 F-150 Lariat, 2023 Bronco Wildtrak
Looks good!
MadMan4BamaNATL
Ray
Atlanta
Dang, I do like the stock beauty ring and thought of adding a bead lock, but with that weight of 39lbs, no way in hell I’d do that along with an E rated tire.
Thone Method FPs you’ve got look pretty darn good. Think I want to go Nitto Ridge Grappler, but only if I can get them in D rated, as E is just too heavy for a daily with the stock wheels.
Are the Grabbers D or E?
Think I’ll need to get over the bead lock look and go with the Method if they have that bead seal function.
Beach_Bum
Ken
St. Augustine, FL
The Methods have what they call "Bead-Grip" which are a series of concentric ridges/rings on the interior bead seat. Obviously not a substitution for a true bead lock wheel. But most people don't need a true bead lock.
The General Grabber X3's are a true MT and are heavy E rated. A different vantage point showing the tread block pattern.
Ford Bronco Ford Performance Method 703 Wheels Weight = 28.4 lbs Luna New Shoes (3)
