2021 Bronco Bolt Pattern = 6x139.7mm / 6x5.5"
NorthShoreBronco
Steph
Canada
www.youtube.com
21 Badlands 2D, 22 BD 4 Door
Is the Bronco Bolt Pattern known? If not here it is....
Selected vehicle: 2021, ford, bronco, badlands, 285/70r17 (a/t) -
STEEL WHEEL 16X7 6X139.7 (Bolt Pattern)
BroncoFanBoy
Brandon
Az
Nissan
Selected vehicle: 2021, ford, bronco, badlands, 285/70r17 (a/t) - STEEL WHEEL 16X7 6X139.7
What is the source for that? Same pattern as the current ranger, right?
NorthShoreBronco
NorthShoreBronco
Steph
Canada
www.youtube.com
I work at a dealership and was just looking to see if any of the aftermarket had listings for Bronco. All I could find was aftermarket rims.
But yea. Would make sense since they are built on the same platform.
Administrator
Administrator
Staff member
Doug
Yes, 6X139.7 has been the working assumed bolt pattern in discussions so far, based on much evidence.
Tons of aftermarket wheels available at this bolt pattern ?
North7
North Texas
SUV
Here is what I found with the search box...
For those of you shopping for wheels, here are the Bronco wheel stats:
Bolt Pattern: 6x5.5" (6x139.7mm)
Offset: 0mm
Backspace: 4.75"
You can see the bolt pattern matches the Ranger 6x139.7mm (6 x 5.5") and not the F-150/Raptor 6x135mm (6 x 5.31").
Here is the Method webpage for reference (Method worked with Ford on the Cyber / 37" Prototype):
105 Beadlock | Matte Black 17x8.5 | 6x5.5" (6x139.7mm) | 0mm/4.75
305 | NV | Bronze 16x8 | 6x5.5" (6x139.7mm) | 0/4.5"
https://www.methodracewheels.com/blogs/news/2020-ford-bronco
This is based on my previous post:
https://www.bronco6g.com/forum/threads/2021-bronco-wheels-offsets-and-bolt-pattern.3546/#post-117373
Disclaimer: Purchasing wheels should only be done once this info is officially released by Ford.
edgeflyer
2013 FX4
Aftermarket is listing Bronco wheels at 6x139.7
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
They are not the same on F150 and Ranger and it is not likely they will change from the Ranger to Bronco.
Mattwings
Matthew
Northville, MI
Dual bolt pattern would be cool. Probably not available in steel?
