270 awning options for the 2 Door Bronco
ElDuderino
Ohio
23' Badlands
Anyone using an awning for their 2 door bronco? Would love to see some pics! There's so many options out there. The main thing that I'm looking for is that it's light weight, and that it can support itself without legs as long as the weather isn't too crazy.
Solfive
NV
2008 JKUR
I have a Freespirit rec RTT and am looking at their 270. If the quality is anything like the tent Iā€™ll be extremely happy. No legs and only 37 lbs if I remember correctly. Check it out if you havenā€™t already.
ElDuderino
ElDuderino
Ohio
23' Badlands
This is a great looking awning and very light weight. Not sure it will fit on the 2 door bronco though. WIll have to look up the dimensions of the roof. 96 inches may be too big.
smelly
Massachusetts
2022 2DR Black Diamond 7MT
swooshdave
Portland, Oregon
Mustang
ElDuderino
ElDuderino
Ohio
23' Badlands
Ironman 4x4 had their 270 recently on sale for something like 50% off.
https://ironman4x4america.com/camping/awnings-rooms/deltawing-270-awnings/
Looks like the discount may still be available.
If you're budget conscious the Rough Country unit is also not terribly expensive.
I don't know how either of these are with the 2 door.
Regardless you'll need a rack.
Yes I have a trailrax trmr rack. Will check these out. Just want to make sure thereā€™s not a ton of overhang. Will look odd.
ElDuderino
ElDuderino
Ohio
23' Badlands
I ended up getting the OVS 270 LT version. Currently on sale until March 31st + found a coupon code online + free shipping. Only ran me $500. 83 inches long, so there might be a tiny bit of overhang. Under 40 pounds as well.
Will post some pictures once everything comes in.
The shop I had install my TRMR rack when it first came in ended up stripping the front roof mounting studs on the Bronco. Have an appointment with Ford on Tuesday morning to see what they can do to fix it.
rufio
Dale
Washington
2023 Bronco
Any pics?
Midnight_Blue
Jeremiah
Los Angeles
Any update on whether Ford was able to fix the mounting studs? I take the roof rack on and off just about every week and Iā€™ve always been curious if itā€™s even possible to repair the mounting studs that will surely rust at some point (the nuts are already showing signs).
ElDuderino
ElDuderino
Ohio
23' Badlands
The part is out of stock. Dealership has not returned my call for 2 weeks to let me know. Had to call a different dealership to find out. Will no longer be taking my Bronco to the original dealership.
ElDuderino
ElDuderino
Ohio
23' Badlands
To follow up, I was also able to fix my stripped studs with a die.
Aonarch
North GA / MT
ā€˜23 Bronco OBX 2DR Lux 2.7, ā€˜16 Corvette Z51
I ordered the OVS 270 LTE to mount on my TrailRax. No pics yet, but I got it through my local overland shop who has done this setup before on 2 doors.
ElDuderino
ElDuderino
Ohio
23' Badlands
Only thing I know is the 90 degree brackets from trailrax need to be drilled to have a wider opening to accommodate for the OVS hardware.
Aonarch
North GA / MT
I went with the low profile ones. I think they should work. I'm ok with drilling.
