- Feb 4, 2020
- 20
- 769
- 889
- Arizona, USA
- Website
- discountti.re
- All Things FORD
- Undecided
Trimming the studs isn't too bad. But definitely a bit of a leap. Good news is you only have to do the rear.@Scott M - no rub on the sway bar at full lock? I get it on compression. I put 1.5ā spacers - but, gonna swap for 1.25 next rotation. 1ā would be ideal, but Iām not willing to trim the studs. I love the steelies too much and really havenāt found anything Iād like to replace them with the right offset (I think 25mm will do the trick). This size has been great. I plan to get their RT Trail series once these wear out. Iām hoping they add some sizes by then.
Rear? Would have to do all four, no?Trimming the studs isn't too bad. But definitely a bit of a leap. Good news is you only have to do the rear.
Nope. The front studs are fine with the 1" spacers and steelies.Rear? Would have to do all four, no?
Just a very small amount of rub on the sway bar. Not enough to cause issue or to concern me. I do have a set of .375" Bora spacers on the way, for cosmetic reasons- I think they will help fill out the fenders nicely and complete the look I'm going for. I want to keep the standard flares and not have any tread poke. I think a .5 or .75" spacer would be ideal but the thickness is limited by the stud length (nut engagement) in the front. 1.25" will look great with the sas flares.@Scott M - no rub on the sway bar at full lock? .....
Iām also not into the larger flares. I hadnāt taken it off-road without spacers - but, Iām sure it would be worse. My observation was just in my driveway and that was enough me to make an adjustment. Guess I need to research trimming studs a bit more. But, wasnāt into the idea.Just a very small amount of rub on the sway bar. Not enough to cause issue or to concern me. I do have a set of .375" Bora spacers on the way, for cosmetic reasons- I think they will help fill out the fenders nicely and complete the look I'm going for. I want to keep the standard flares and not have any tread poke. I think a .5 or .75" spacer would be ideal but the thickness is limited by the stud length (nut engagement) in the front. 1.25" will look great with the sas flares.
I did not realize that. Thanks for the info.Nope. The front studs are fine with the 1" spacers and steelies.
Steelies unite!small update- I did a test fit with the .375" (10mm) spacers and the wheel studs on the front hubs are not long enough to allow for proper lug nut engagement. I was only able to get about 3.5 turns of the lug nuts on the front and about 5 on the rear. I know that some are running the .375" spacers, but I didn't feel comfortable with so little lug engagement and took them off. Unfortunately, extended lug nuts won't work either since the holes in the steel wheels are too small for the shaft of the extended lugs to pass through.
It did look subtly better with the spacers on - really put the tire tread right to the edge of the std flares. oh well.
Good news though is that the tire rub on the sway bar is very minimal even after 3k miles and a bunch of off roading with full articulation. (see photos below) I'm even less concerned about it than I was before. While the wheels were off, I also combed over every inch of the wheel wells and couldn't find any additional rubbing.
And after 3,000 miles we're still loving the tires. They really added a bunch of capability with the added ground clearance and they drive great on the road. They can be a little low on grip in the rain when pulling away from a stop, but they deal with standing water well with no hydroplaning. The tread still looks great even after many gravel forest road miles too. As a bonus, my wife recently averaged 20mpg driving from Seattle to Portland and back at about 70-80mph.
And we're still very happy with how they look. Here's a shot from a recent offroad day at DirtFish taken by GallatinImages. Fits right in with the Genadiers on the steel wheels:
Yeah you have to do 1.25" bolt on spacers to clear the steelies. I did 1" bolt on's by trimming the rear studs a smidge.small update- I did a test fit with the .375" (10mm) spacers and the wheel studs on the front hubs are not long enough to allow for proper lug nut engagement. I was only able to get about 3.5 turns of the lug nuts on the front and about 5 on the rear. I know that some are running the .375" spacers, but I didn't feel comfortable with so little lug engagement and took them off. Unfortunately, extended lug nuts won't work either since the holes in the steel wheels are too small for the shaft of the extended lugs to pass through.
Thinking about getting the 285/75R17 Toyo tires after my General Grabbers are done and I've been through this thread a few times. I plan on keeping the steelies as I really like them. Just wanted to clarify a few things that are unclear to me:Yeah you have to do 1.25" bolt on spacers to clear the steelies. I did 1" bolt on's by trimming the rear studs a smidge.
1. Are spacers absolutely necessary when getting the larger tire? If I'm keeping the stock steelies I mean......
2. Why would you trim the studs if you're putting on a spacer? Doesn't that make it so the studs are even less engaged with the lugnuts? I must be missing something here.
3. After putting on the larger tire, is recalibrating the speedometer with Forscan required?
4. Leveling/lifting required at all? I want to avoid doing too much modifying.
Thanks to Scott, GiJo, redone, etc for all the info and photos.
HUGE help. That is great thanks. I'll look into the FP 2" lift - can you send a pic of yours with the lift?I've got 285/75R17 Duratracs on my BD factory steel wheels.
In my experience. No Spacers, No idea about trimming studs. You need to recalibrate. No level/lift required. But I didn't get off road with them. I got the Ford Performance 2" lift installed after having the Duratracs a few weeks, I bought it on sale before I picked my tires.
1. Are spacers absolutely necessary when getting the larger tire? If I'm keeping the stock steelies I mean......Thinking about getting the 285/75R17 Toyo tires after my General Grabbers are done and I've been through this thread a few times. I plan on keeping the steelies as I really like them. Just wanted to clarify a few things that are unclear to me:
