Thanks for all the info - it turns into the same heights as a F150 on 2” fox on 35’s.4” with 37’s
Great info, it gives me perspectuve because my brother is 6'7" and I could still kick him in the tuchus.Total height from the ground to the top of the soft top is right around 6’ 7”. Ground to the step, just under 1’ 8” and ground to the bottom of the rocker is just under 2’.
Does the Bronco next to yours have the stock Sasquatch 315s? If so your tires look more like 36s but I thought 325s are only slightly bigger than 315s?Here you go!
Any rub?Mine on 37’s with 4” zone lift. So far so good.
What size rim offset and tire. How does it ride? Steering still rock solid? What lift did you decide on?Here you go!
Beautiful, what offset on your wheels? The wheels I want (18x9 +18) with 37 Nitto Recons and a 3.5” lift should still have a bit of pokeMine on 37’s with 4” zone lift. So far so good.
