- Sean
- Jul 29, 2020
- 112
- 231
- Seattle, WA
- Jeep
I second this. Would be very helpful...if it’s not too much trouble. Thanks!!Can you do these with white tops?
I don't think that's a good visual accuracy for AMB, but I'm def going with AMBStill so disappointed in how dark AMB is. In fairness the gas can pictures make it seem a little lighter than rendered here. I suspect I’ll be taking a trip to the dealer to check out the f150 when it arrives. Great job, dude!
Added white tops! It's only half of the roof because the front has the optional soft top opened, but should hopefully help you visualize the white top a bit more.I second this. Would be very helpful...if it’s not too much trouble. Thanks!!
This is AMB on the 2021 F150.Rapid Red - IMO, looks the best. But I’m simply not a red car guy, and will probably regret it or feel out of touch with the car (as strange as that is to say). Would be my choice if I leased it, but plan on owning for a very long time.
Carbonized Gray - By far the best safety pick. Looks good and would satisfy long term
AMB - I’m getting this with a white top and will not allow dark renderings to change my thoughts.... It’s a heritage build and if it’s darker than I would like it to be I could still sell myself on the idea that it’s original. At least it adds some excitement with a pop of color in the sun compared to CG. Something tells me when I see a re-creation of the Leno build I’m going to want to run up to the car and hug it. That’s when you know to stick to your gut and pull the trigger.
It looks great here, but this is a super controlled environment as far as lighting in concerned. I need to see it in the wild.
that helps a lot!! Antimatter blue with a white top looks fantastic. White Bronco lettering on the front to tie it all together.Added white tops! It's only half of the roof because the front has the optional soft top opened, but should hopefully help you visualize the white top a bit more.
