4x4TruckLEDs.com Front License Plate Mount
Brichan
Bill
Ram 1500
I was excited to finally see a front license plate mount I liked available through 4x4truckleds.com.
it mounts directly to the Bronco Bolts in the middle of the modular bumper. I went to install it today and the Bronco bolts it goes to seem like they won’t budge at all and trying to hard will strip them right off. Any one else using this mount and find the same issue removing these Bronco Bolts?
Wide Open Roads
Stace
Massachusetts
'09 Outback, '57 Alfa Romeo Giulietta, '10 911 C2S
What are you using to try and remove it? Just a regular ratchet? Have you tried any PB Blaster or WD in case the bolts are frozen?
Bronco21fan
Angelo
NewJersey
Ford Bronco 4x4TruckLEDs.com Front License Plate Mount B2CF6B44-EB9F-4923-9850-E05DB59D4713
You need torx plus bits to remove the bronco bolts from what I read in the forums for some reason ford includs regular torx bits that strip the bolts
Headsong
Bought mine.
Brichan
Brichan
Bill
Ram 1500
This is what I needed to know. Very frustrating
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Welcome to the world of "WTF Ford!" We've all been there. So Ford decided to use a TORX PLUS head for some strange reason. Maybe it's because TP is a better pattern when it comes to how tight the socket fits on the bolt head.
But it's NOT a standard Torx socket, which most would think it would be. It's a TORX PLUS, which is separate.
A regular Torx 40 WILL fit, but it doesn't grab that well. You need a Torx Plus 40.
I'll update our site (both on the fog kits and the license plate bracket) making a note of this.
Brichan
Brichan
Bill
Ram 1500
Can’t get the Torx Plus 40 to work either. May have to just give up and hope the police don’t notice I don’t have a front plate.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Why can't you get it to work? It should come off no problem with a TP40. Unless you stripped the bolt head?
Brichan
Brichan
Bill
Ram 1500
Finally got it. I guess I’m legal now. You should include one of these TP40s in your $60 license plate bracket 😉😉
FlyingBronco
The Don
Orange County, CA
Ford Bronco 4x4TruckLEDs.com Front License Plate Mount 6A025FD0-A85D-44AC-92FA-63144B153FE0
Nice! I might buy one since Colorado requires a front plate, as well. Hope I remember to take it off when hitting the trails, though!
