Ryan at ARB
Ryan
Auburn, HI
arbusa.com
Jeep LJ, Ford Ranger, Ford Bronco
Ford Bronco Ford Bronco ARB BASE Rack – First Look! 6g2
When the team of ARB engineers were tasked with designing and developing the BASE Rack for the Ford Bronco, our wish list was to release a rack that was as low, quiet, and strong as practical while also retaining the functionality of the front hardtop panels.
Ford Bronco Ford Bronco ARB BASE Rack – First Look! 6g4
Developing a low-profile roof rack doesn’t just ensure the vehicle will fit in parking garages – it also keeps the center of gravity lower, it's more aerodynamic, minimizes wind noise, and provides a sleek aesthetic. Our team developed short blade mounting rails that allow the BASE Rack to add only 3 1/8” from the top of the roof to the top of the rack.
Ford Bronco Ford Bronco ARB BASE Rack – First Look! 6g5
Noise reduction was next up on our wish list. Accompanied by the low-profile rack is a 2mm aluminum wind deflector that is form-pressed to follow the specific contours on the Bronco hardtop. This minimizes both wind noise and vehicle drag.
Ford Bronco Ford Bronco ARB BASE Rack – First Look! MicrosoftTeams-image (23)
When developing parts for off-road use, strength and durability are always a priority. For this reason, we chose the factory roll bar system and body as the main support system. This has allowed us to obtain a 285lb dynamic load rating. To achieve this, drilling the hardtop is required but stress free due to our waterproof gaskets and roof support brackets. BASE Rack is also manufactured from extruded aluminum beams with single seamless box piece aluminum and internal bracing putting the load rating for each beam at 50lbs.
4-door Ford Bronco BASE Racks are offered in 51”W X 61”L. This size provides maximum storage while retaining front panel functionality.
An option for the 2-door Ford Bronco is being reviewed. Let us know if you’d like us to develop a BASE Rack for them!
Ford Bronco Ford Bronco ARB BASE Rack – First Look! 6g6
Dovetail Mounting System
T-slot channels have become a popular addition to roof racks, creating simplified installation of many roof rack attachments along the internal beams. But when it’s time to remove the accessory, you must slide the attachment across the entire rail which has the tendency to get hung up on dirt, pebbles, and other debris.
The BASE Rack takes accessories and cargo loading to an entirely new level of simplicity, speed, and personalization by incorporating a dovetail excursion around the full perimeter as well as along each of the internal beams. This creates more possibilities for mounting locations while also lowering the mounting point to complement the overall low-profile design of the rack.
Ford Bronco Ford Bronco ARB BASE Rack – First Look! 6g1
Your Rack, Your Way
One of the core features of the BASE Rack is its overall flexibility and the ease of which it adapts to suit your needs.
The customizability is unmatched with over 50 different accessories and four different rail systems. The BASE Rack modular rail system is available in full rail, three-quarter rail, quarter rail, and trade rail configurations. All rail systems are also available separately.
The accessory range consists of but is not limited to fuel tank holders, awning brackets, spare tire straps, t-slot adapters, and lighting kits. It’s also compatible with aftermarket accessories such as t-slot attachments, mechanical jacks, recovery boards from TRED and Maxtrax, and Rotopax containers.
Full accessory list here.
Worried about clearing your garage? No problem! The dovetail extrusion accompanied by the ARB Quick Release Accessory Brackets means you can have the rack bare in just a few minutes.
Ford Bronco Ford Bronco ARB BASE Rack – First Look! 6g3
Key Details
-51” X 61” Modular Rack
-Adds 3 5/32” (80mm) to the roof
-285lb dynamic load rating
-Maximum load per beam is 55lbs
-Loads must be evenly distributed and adequately secured
-Hardtop and roll bar mounted (requires drilling through the hardtop)
-Retains front panel functionality
-2 Door option is under consideration (feedback needed)
-Compatible with the full-line of ARB BASE Rack accessories
Shop Ford Bronco ARB BASE Rack
Ford Bronco Ford Bronco ARB BASE Rack – First Look! 6g7
FleshTuxedo
A
PA
'22 OBX 2dr.
Oh boy! This looks great!
taconic41
peter
DeLand, FL
Black Diamond, Sasquatch, 7MT, Race Red.
i have been waiting for this one for a long time. the accessory system looks to be very versatile, and rollers attached to the sides would help in getting my kayaks up on the roof. how many holes do we need to drill, and where? diagrams/video showing that process would help with the concerns that many will have about putting holes in the roof.
Sumo
Sam
Georgia
Subaru wrx sti
Yes, please develop a base rack for the 2 door. I might be interested, if Ford ever gets around to scheduling my build.
acf1016
Denver
2016 Cherokee
Your Rack, Your Way
Full accessory list here - https://arbusa.com/roof-racks/arb-base-rack/roof-rack-accessories/
Key Details
-260lb dynamic load rating
Estimated Time of Arrival (TBD)
Estimated MSRP $1,500 (Includes mounting system and flat BASE Rack)
Please develop for the 2-door
heelyeah
Tripp
2021 Bronco; 2022 F150 Lightning; 2021 JT (wife's)
Your Rack, Your Way
Key Details
Any idea if it will be compatible with the Bestop Sunrider? Looks like probably not?
Jamiegla1
Jamie
Baton Rouge
Soon to be 1st time Bronco owner
also interested in this. I was totally sold until I saw drill
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Ryan at ARB
Ryan at ARB
Ryan
Auburn, HI
arbusa.com
Although we haven't tested, I'd guess that our rack would interfere when you try to rest the Sunrider back.
