adaz
Bill
Nebraska
2018 Toyota Tacoma TRD Sport
This is the 3rd year i've come up fishing here and my third year with my bronco (yellow; badlands, lux package, 2.4 manual) figured i'd finally write a trip report in case anyone else with a Bronco wanted to know how the trails are up in this part of north central/north east Minnesota.
Also i'm not like... a super driver or anything. I live in Nebraska and while i've owned 4x4s mainly never done much outside snow/farm work with them. So, this is basically from perspective of "super beginner who occasionally has watched videos on 4 wheeling on youtube".
Iron Range
This is located in an old iron mine area and is... pretty intense and cool. The area has a wash station which you will want to use, get oto that later, and a park ranger station where you can buy the pass you need . I believe there are techniclally over 100 miles of trails although not all are open to OHV vehicles and some.. well. I dont think a stock bronco can make. I think I paid like $50 for a 2 year pass. The trails here range from sure no problem to you absolutely need a dedicated rock crawler rig to even attempt them. They are clearly marked. The easiest (green) I would suggest anyone even without much 4 wheeling experience you can put your bronco into mud ruts and just have a good time. No worries about getting stuck or breaking anything. The blue (harder) are where you need some experience and where you can, if you screw up, get yourself stuck/broken pretty easily. The _black_ I would never attempt honestly. They are beyond my skill level.
This is an example of a black - hercules hill. It's 150' at i dont know, 50? vertical.
Ford Bronco Iron Range and Spider Lake Trails (MN) trip report herculeshill
Ford Bronco Iron Range and Spider Lake Trails (MN) trip report goodluck
Or you have stuff like "tipsy" which you could ... maybe.. do a bronco through but i uh wouldn't.
Ford Bronco Iron Range and Spider Lake Trails (MN) trip report tipsy
Now the good parts. A lot of good wheeling. There's a connector trail that runs between the two areas that will definitely test your skills. It's a few miles long and basically nothing but 4-10 inch rock and a lot of very fast vertical ascents/descents. You also get stunning views although note the very iron stain on the bronco. That took me a year to get off the plastic molded bits because I didn't follow the adivce of the rangers/locals and _immediately_ wash the vehicle because it looked cool (it does look cool). I spent basically the entire 3 hours I was there in mud/ruts mode and using and abusing the crawler gear. it works fantastic and really if you just pay attention to the basics - your clearances, keeping your tires on the rocks, etc it's all really doable and enjoyable. I dropped my tire pressure down to 30 psi for this course. There's a free app that will plot out the courses for you and all the rangers will help out a bunch if you have questions.
There was a pretty gnarly straight up into mud to axle section which I was legitimately suprised bronco made it through buried up to its axle in mud and kicking up rooster tails but it did. The trails tend to be in short sections - maybe 1, 2 miles _at most_ before it dumps you back on the main road.
The only thing I did not attempt - on advice of the rangers - was the mud run. They thought i'd _probably_ be fine but suggested a winch as a tow if you got stuck was going to be ... pricey.
Ford Bronco Iron Range and Spider Lake Trails (MN) trip report bronco
Ford Bronco Iron Range and Spider Lake Trails (MN) trip report bronco2
Spider Lake
This was the first OHV course I ever tried in the bronco and it remains one of my favorite. it's 29 miles of trails in sandy/rocky terrain. I spend most of the time in mud/ruts mode with the occasional shift into sandy for the "dune" parts of the course. This is just fun wheeling, the only thing I would suggest or might be intimidating is there are a _lot_ of little ponds you got to drive through and the depth can be ... deceptive. One we hit and the water went well over the bumper and nearly to the hood until we floated a bit and hit the other side. That was unexpected!
For the most part though you're dealing with mud, ruts, tight turns lot of sandy soil and a LOT of straight up verticals and straight down descents relying on the trail cam and the crawler gear to get you up/down.You do share the road with a decent amount of ATVs and side by sides. The trails here can run for miles before you run back to the main road. Also... the breakover angles can get you if you're not paying attention so helllo skid plates.
Over all this isnt necessarily _challenging_ outside the water dangers and the straight vertical ascents. Really, put the bronco in mud ruts and keep your tires on the big rocks and just let it go. My 77 year old uncle and my brother, having never driven a bronco, took turns in here and all found it super fun with only moderate amonts of screaming.
About biggest negative is it's a forest in minnesota. You _can_ leave the top down but god save your soul if you stop for very long you get eaten alive by mosquitos.
Ford Bronco Iron Range and Spider Lake Trails (MN) trip report bronco3
Ford Bronco Iron Range and Spider Lake Trails (MN) trip report bronco4
Laddyaddy19
Landon
North Dakota
Nissan Altima, Evo X, F150
I’m thinking about try the Spider Lake Trails on Friday. Did you have to air down the tires much? I don’t have a very powerful compressor and that is my only concern.
adaz
adaz
Bill
Nebraska
I left them at 35 PSI. Probably a bit much - 30 or 25 is honestly probably better - but it was fine. There's a couple nearby (ish) towns that have gas stations you can air them back up at, depending on which way you are coming 10-20 miles away. But i've also been lazy in previous years and just run at 40psi without problems.
BoldNorth
Minneapolis, MN
'24 HPR Wildtrak, '95 Mustang GT Convertible
@adaz Thanks for the great trip report! Looks like a fun area for all skill levels.
LCW
Twin Cities, MN
2019 4R TRD ORP, 2023 Bronco 2dr Badlands (gone)
OP - check out the Mesabi Mountain Trail when you get back up there. It’s right in Eveleth.
Laddyaddy19
Landon
North Dakota
Yeah I am thinking I’ll air down to 30 and call it good! Thanks so much!!
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Iron Range
Spider Lake
Thank you so much for sharing your experience with us! :)
adaz
adaz
Bill
Nebraska
So this one scares me as the description is like don't try without 35 inch tires and a winch!!! How hard is it really?
Also I don't have hardly any experience with rock crawling something hoping the off roadeo will help with here in a few months.
  • Like
Reactions: LCW
Felix808
SRV CA
Nice write up, looks like you had a great time.
If you are airing down to 30 psi, what the heck are your road pressures 🤔
If you haven't aired down to below 20 lbs. (Ideally even less), you haven't even started to air down $.02.
adaz
adaz
Bill
Nebraska
Oh for sure these are super fun trails and areas. Highly recommend.
39 psi up to 41 or 42 depending on how hot it is outside. My bronco sadly spends a lot of time on the interstate.
And you're probably right but I don't have a portable air compressor so I didn't want to go below what the tire said was minimum until I got to the nearby ish gas station. This makes me curious what folks with non Sasquatch builds run though, you guys really drop down to 20?
Felix808
SRV CA
LCW
Twin Cities, MN
Yeah it's a bit more difficult. There are many bypasses though - possibly for most every obstacle. The biggest issue is maybe high centering. I wouldn't do it alone I guess. I did it last year with a group from Crawl 4 The Cure, when I had a JL 4 dr. Although I was on 37" KO2s (smaller than some other 37s). A guy in a JL 4-dr on 33's struggled but other than a couple high centers, he could take bypasses as needed. A 2dr wouldn't have as many high centering issues.
One major bonus of this trail... No RED RUSTY DIRT!!!
SeptuagenerianSasquatch
Randy
Massachusetts
Thanks for the great write-up. And those images! Trails like that give me gooseflesh. ("Gooseflesh" can be caused by excitement, but also by fright, you know.)
Minnesota will definitely be high on my list for consideration in 2025. Maybe tie in with Badlands and Montana.
Tdub0527
Ted
Minneapolis
'21 Bronco Badlands, 2024 Rivian R1S
I did a write up of the Iron Range Off Road park last year, check it out here: https://www.bronco6g.com/learning-to-wheel-the-bronco-at-iron-range-mn/
I had a nearly stock Big Bend Bronco 3.73 gearing on 33” KO2s that tackled nearly every obstacle. The Iron Range is a super cool place. For reference I was aired down to 15 PSI and it helped a ton.
adaz
adaz
Bill
Nebraska
I read yours last year actually and never replied; it's what caused me to go out there for the first time so thanks a ton :). I looked this year to see if they were offering a course when I was up here but alas, they weren't. A really good idea though I think for those who want to check out that area -- having experienced trail guides up there would be worth a lot and i'm sure you'd learn a ton. I can see how with guides you can probably do _most_ of the things in Iron Range although I do question some of the gigantic boulder courses which seem like you'd need a rock crawling rig for sure. And hercules hill because I'm pretty sure that angle is way more than the bronco is rated at for stability.
For me at least it was getting over a bit of fear - like @SeptuagenarianSasquatch is kind of saying - and realize nah bronco be fine. Easily able to handle it and you can just have some fun. Do what's comfortable for you for sure and practice your skills but both those areas have a ton of fun wheeling. Like you're saying I don't think you even need a badlands or w/e Broncos of all levels should have a ton of fun
