thanks!To do so oem would get expensive. From what I understand, thereās a different video module thatās really pricey and Iām not sure if it needs the big screen. Depending on your intended use, Iād look at cheap aftermarket cameras and external display similar to what @Ground_zero298 did here.
If you want to use the 8ā built in, @cjindna has reported good experience with the Naviks adapter that integrates external video feed. Post about it here
