Advice on best after market mud flaps needed
Shane78
Shane
St. Louis
2D
Silly question — but is there a reason why most of the mudflap designs I’ve seen are solid plastic rather than firm but flexible rubber? If the ultimate goal of mudflaps is to block ejected ground debris then wouldn’t rubber also do the job while also being flexible enough to not snap into pieces if they catch a rock or the curb at an awkward angle?
I ask because these plastic mudflaps look like they’d shatter or snap off if the tire they’re mounted on hops off a rock or a curb and snags it just right.
Can’t answer your question, but I will say RekGen and Rokz are both pretty stiff but flexible at the same time (even tho that’s a total dichotomy).
Shane78
Shane
St. Louis
2D
Are they quick-release?
Nope, 3 screws into existing holes in the liner + 1 trim pin screw. I didn’t have an issue with them doing some moderate trails. Heard them drag a few times, but they flexed and rebounded.
BroncoOvrlndr
Charlotte, NC
Audi Q5
I’ve been happy with the Rekgen Trophy Sport front mud flaps! It’s kept the rocks and wet leaves after it’s rained off my Bronco, and it’s got a sleek minimal look.
Nay
Nay
Renee
Dealership has no estimate. Ordered 08/10/21.
That’s a bummer but I can’t wait to see pics when you do get it!
zombie
New Brunswick, Canada
2021 Bronco Badlands (7spd) 2022 Mustang GT PP
Bottom of the gatorbacks is thick rubber with a plastic backing (where the bronco logo goes if you buy the "more" expensive branded ones). And the bottom part of the gatorbacks is removable without tools for when you're doing rock crawling or whatever.
For me, the non-branded gatorbacks were the best option, they're expensive but "worth it" imo.
Nay
Nay
Renee
Can you share a link to the non branded gator backs?
  • Like
Reactions: bek
zombie
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
Ford Bronco Advice on best after market mud flaps needed 89CC096C-FA3E-457F-BCCF-BD21B2BC9A45
Ford Bronco Advice on best after market mud flaps needed 9B5A7353-55EA-41E9-809C-B83F6CC3306A
I
I ordered the ford splash guards for front. Mine is a 22 big bend. I added 35 inch tires. I had to move the stock running boards 1 inch back to accommodate the splash guards. I wasnt happy with any of aftermarket options and these fit like a glove and cost 55 bucks. Total install time with moving running boards was 1.5 hours. If I didnt have to move boards it wouldve been 15 mins. Im happy with them. I wont be adding rears. I dont like mud flaps to start with but wanted to protect paint from rocks and snow/mud.
HBTFD
Newnan GA
F350
Get ones that hang really low otherwise the rocks will hit your doors.
  • Like
Reactions: bek
Skeld
Hampden, ME
2022 Chevrolet Silverado 2500 HD
What options have been proven to work with Outer Banks steps?
Cleecvt1
Christie
Purchasing a 2021 bronco
I got a set of rokblokz and can't get them installed. The front bolts at the crash bar are super torqued on and can't loosen them even with a torque wrench....may be sending back.
shoelessjoe
2013 Chevy Cruze
I wouldn't loosen bolts with a torque wrench. You will ruin the torque wrench.
Cleecvt1
Christie
Rekgen trophy sport has been adequate for me, and pretty straightforward install. They have stopped the gravel spit, and look clean. I just bought the front at first and thought they were good but buying the rear now too since I added a high end bike rack and pivot. Well worth it. And cheaper than others.
Edit: I should also add, I compared to my friends rokblokz and we could not discern why the rokz were 2.5x more expensive. Basically identical.
Wish I had seen these
Cleecvt1
Christie
Ive got to go to a custom place to have them installed. Should have gone w gators and used my ford points!
