- Jun 3, 2019
- 18
- 876
- 2,844
- Plymouth Michigan
- Website
- www.brokeninnovation.com
- 2021 Bronco Badlands non-sas 4 door manual
- Badlands
Thanks, this is the info i'm looking for. I think there is a market for fenders that let you clear bigger tires with your stock full wheel travel, or even increased wheel travel. And that market is separate from the one that wants to spend 10k on APG's sick carbon fiber ones. I know there is another brand that makes legit high clearance fenders (blanking on the name) but they dont look as nice as ADV's or OEM IMO.From Carli's website.......................
This starts with the fenders. We knew we wanted 37s; our first call was to John over at Advanced Fiberglass Engineering. He walked us through their options and we chose their 2″ Flare, 1″ Rise Front Fender Kit, Front Fender Liners and matching rear quarter kit and door trim with the heat-extractor hood. The fit and finish on their products is second to none; we’re used to the crappy quality of fiberglass and were thrilled once these were installed.
We chatted with a few in the industry to hear the the “standard” for 37s is ADV fenders and 0 offset wheels. We grabbed some KMC Tank Beadlocks and Mounted our 37×12.5″ tires. We pulled the coils to cycle the suspension and found the tires hit the fender itself (on the top of the wheel arch and back of the front wheel well) and the fender liner. We quickly figured out we were on our own as those advising us didn’t cycle the suspension but, in wheeling their Broncos, “got very little rub”.
It was hard to say goodbye to the 0 offset Tank Beadlocks but, the first order of business was to swap the 37s to our factory Sasquatch wheels and add some Ford Performance Beadlock Rings to secure the tires. The 17×8.5″ wheels run a +33mm offset which positions the 37″ tire in perfect proximity to the ADV fender and our upper control arm. We’re so accustomed to ultra high offset wheels from the factory (Like the non-Sasquatch +55mm offsets) that we didn’t think to check the Sasquatch wheels first – sure would’ve saved us a headache.
With the tires fitted to the factory wheels, we had to do some customizing. The crash bars in the fender well got removed, bases chopped for clearance, then plated and welded. We then clearanced the necessary bits of the ADV fender & built our own inner fender liner/splash guard (to go between the pinch weld and ADV Fender) to combine with the factory liner. With these modifications, the factory Sasquatch wheel properly cycles a 37×12.5″; we’re off to the races (well paint)!
https://www.carlisuspension.com/ford-bronco-rd/
Side note: They are making a really nice double shear tie rod.
