Who wants 40s? THE OFFICIAL 40 INCH TIRE THREAD!!!
Erock
US
2018 F150 Alpine edition
Diff drop... I understand that you lose some clearance, but it’s between the tires, no different than the rear axle.
vrtical
Doug
GSMNP, TN
Fords
Portals....
MSparks909
Miles
ENC
2014 Ford F-250
To run 40s properly...while keeping the IFS functional and retaining the benefits of the Bronco over a Jeep, start thinking along the lines of this build:
If you’re gonna go for a solid axle swap, just start with a Jeep. Known quantity, bolt in Dana 60s, etc
Buckin Bronco
ChoSunJuan
Canada
2004 Nissan Xterra
Once you do that you lose some of the ground clearance you were trying to gain with the 40s.
Vicious cycle.
How is it an different than a solid front axle or the rear axle?
A Jeeps axles stay where they are when a suspension lift is added, any ground clearance gained is through increased tire sizes.
Please correct me if I'm wrong.
swooshdave
Portland, Oregon
Mustang
Because with a solid axle you aren’t lowering the axle to accommodate the half shaft angle.
Note that I’m not saying you’ll have less ground clearance than a solid axle, just less than what you thought you’d gain with the 40s.
RLW
Robert
Chattanooga, TN
2000 Lexus GS 300, 2022 Badlands, 2022 Honda Odyss
I don’t even want to know the cost of this build.
I also can’t wait to see this exact thing done with the bronco.
It’s going to be great!
Buckin Bronco
ChoSunJuan
Canada
2004 Nissan Xterra
Technically you aren't lowering the diff, you're keeping it at stock height. It should have the same ground clearance height as the rear differential.
CarbonBronco
Tony
Socal
99 Toyota $runner
Here comes the my wiener is bigger than yours contest… I’m straight I’ll stick to 35”s 37”s if I’m feeling frisky.
dcmdon
Don
Metro-West Boston
Also, when a solid axle suspension compresses, you don't lose ground clearance at the lowest point. On a IFS you do.
mynameismyles657
Myles
Charlotte, NC
2017 GTI
Please enjoy the worlds worst photoshop job of 40's on a 4dr!
Double checking now to make sure the wheels are the right size....
Ford Bronco Who wants 40s? THE OFFICIAL 40 INCH TIRE THREAD!!! DSC_1493-1024x684 v2
