Any roof racks that allow the soft top to function normally?
Lambeezy
New Jersey
Base 4 Door Bronco
Are there any roof racks available that allow the soft top to function normally? I've seen the body racks on wranglers which work with soft tops, but I can't find if they allow for the top to go up/down.
Rspayde
North Ga
2022 C/O Black Diamond
I will be getting these once mine shows up (hopefully in a month or so). I do not see why or how they would impede the soft top going up/down. That being said only having use while the top is off could cause problems for some.
There is only one option I have found for a permanent solution but it does not allow the soft to be moved while on.
https://www.smsparts.com/product-page/2021-ford-bronco-4dr-soft-top-clk-red-roof-racks
SLCBronco
Cory
2021 Bronco Badlands
Calm horse
MO
Georgia
17 f150 king ranch
Raket should be coming out with theirs in about a month or 2
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
Gobi has theirs, but it’s pricey and widens your Bronco quite a bit.
Mikehoncho
Maryland
Big Bend Sasquatch
The barricade is the only one I've seen that is wider than the soft top and extends to the back far enough so that the soft top can be operated without removing the full rack. Still have to remove the cross bars of course but those are thumb screwed in place and easy to remove.
