Any updated info about tuning?
Stitches1974
SW Florida
2019 Dodge Challenger Scat Pack
Those don't have the 7-speed in the bronco. New transmission with a supposed torque tolerance close to where a tune gets you. Knowing people that tune generally do other mods, sounds like a recipe for lots of blown transmissions.
Mustang has a different transmission. And the ranger doesn't have an engine option with HP numbers almost identical to what the 2.3 gets with a tune. I hope I'm wrong, but I wouldn't take it as a given.
I totally missed the 7 speed comment in the first post. My bad. Not sure why this isn't in the 2.3 section. Probably why it threw me off.
Either way, I would still expect them to have a 2.3 tune for the bronco, no matter the hp gain.
elseminoleguapo
Javier
Miami
Basesquatch
If Ford confirms it before order time I might be locked in to 2dr basemansquatch. Otherwise V6 likely. ?
DrewBronc21
New York
2020 Subaru STi, 2024 M2
There’s also a tire size limit to 32”...”The tune requires premium fuel only and allows for tire size configuration up to 265/70/17”
Gr8Hortoni
Gr8Hortoni
Whitehall, Michigan
I don’t get why the tire size would make a difference other than speedo calibration. As far as the hp/torque limits on the 7 spd, I would think that the ford performance tune (and the 5 star tune from what I’ve seen on the Ranger) are within the factory limits for regular use, albeit towards the top end.
mans sorry for the confusion, it was meant more as a 2.3 vs 2.7 question in regards to numbers, options and tuning limits.
DrewBronc21
New York
we will find out how much torque the 7MT transmission can handle. Just because it has a rating on paper doesn’t mean it can’t handle much more. Apparently its “scalable” to 590 torque but not sure what that means or how it’s accomplished. Maybe there will be options to modify it as well.
