AR | MAGNUM STIRRUP® Full Length Billet Aluminum Side Step for OEM Rock Rail - Bronco6G Exclusive Part
Billnchristy
William
Georgia
2022 Bmw m440i gc,2022 BD 2dr, 1966 mustang
Got my shipping email yesterday! Should be here Friday. Hopefully we can slap them on before the Rolex 24 starts...who knows we may do it in the dark Friday night. :LOL:
splytsecond
J
Chicagoland
cars
I ordered 12/31. Received an in production email on 1/21! 😊
Thanks for posting this, looking to order in the next two weeks or so and was wondering what the lead time was these days.
BeardedRanger
Matt
IL :-(
Bronco Black Diamond; Ram Rebel 1500
You bet! I’ll update when they ship.
Johnny475
Johnny
Wisconsin
Volkswagen Touareg,Volkswagen Tiguan
You already knew we weren't going to stop with just the STIRRUP. Ladies and Gentlemen, I bring you the MAGNUM.
AR | MAGNUM STIRRUP is live on the website for pre-order. We crunched the numbers and bought up 240' worth of 6061 billets to get the product more cost comparative to the 4 door STIRRUP. There's just no way getting around the volume of material necessary to make this size magic happen.
2 Door: $1,245.00
4 Door: $1,395
With the Bronco6G 20% forum discount, it's shipped to your door for:
$996 for the 2 door
$1,116 for the 4 door
Some of you hit pause on your STIRRUP order to allow the release of the MAGNUM pricing. Go ahead and fire off another email ([email protected]), if you're a go or no-go. If you're a go, we'll create a special code at checkout for just the difference of the MAGNUM. For everyone else that has already said SEND IT on the thread, we'll PM you the 20% off code. The 20% off code will be available to all Bronco6G members forever ever.
We're using 12' x 6" x 1.75" of USA made 6061 billets that we are cutting down to size, and machining right here at STARKILLER BASE, to make each and every MAGNUM STIRRUP. If you have an overland build, trail conquering rig, or your daily driver the MAGNUM will fit the bill. It's five inches of width will give your boot or shoe a proper platform to assist you in climbing up in the saddle, conveniently reaching gear on your roof rack, it will protect your BRONCO from shopping carts and car doors, or just something awesome to admire.
Those of you that have any of our products know that nothing we do is rinse and repeat jeep level engineering. This is all multi-op, chamfered edges, post machining, color matching OEM+ GOODNESS. Our entire intent is for our MAGNUM to look like it was on your BRONCO from the factory.
Let's call it 60" for the two door MAGNUM and add fifteen more inches of length for your four door MAGNUM. I've been around billet car parts for a while and the MAGNUM has to be one of the largest billet aluminum parts to be used and semi mass produced in the automotive world. It kind of has to be, to be called the MAGNUM, right?
The entire MAGNUM, along with its Clamps, are coated in a powdercoat that we went to great lengths to, to ensure it closely matched the color that FORD uses, furthering the OEM+ appearance, and not a aftermarket bolt on. Then, if you so choose, we post machine to remove the powdercoating from the top surface and reveal the raw billet aluminum and provide a very classy contrast. This will also give the MAGNUM years and years of striking good looks and no rust... ever. The more you step on the MAGNUM, the more naturally worn the aluminum will look but it won't affect the powdercoating.
MAGNUM is mounted to your OEM rocker rail with 4 Clamps each and M8 and M10 316 stainless fasteners. Nothing but the best. A single M8 bolt alone has 110,000 PSI tensile strength! The MAGNUM is definitely more solid than the rail it's mounted to. With its coating and the use of aluminum and stainless, the MAGNUM will require little maintenance and it will last the life of your Bronco.
The MAGNUM will be sold in a pair. You'll select 2 Door MAGNUM or 4 Door MAGNUM from the drop down. This will also be a BRONCO6G exclusive part, at launch, and B6G members will always be eligible for the 20% discount.
AR | MAGNUM Clamp Bracket
The Clamp on bracket is standard for both 2 Door and 4 Door MAGNUM. Both the 2" drop location and standard height (more even with the top of the OEM slider, are available on the Clamp Bracket.) This is the same tried and tested Clamp used with the AR | STIRRUP. We just doubled up the clamp number for both looks and just in case you want to take a family photo of everyone standing on a MAGNUM. *The first family that posts a pic doing this will each get our new Overland Bronco shirts. ;)
The Clamp is secured with a pair of M6 316 stainless steel bolts. We apply a heavy duty rubber isolator to our Clamps to ensure there is zero metal on metal contact with your OEM rail. No metal chaffing means no wear on your rock rail's finish. And for those in the salt belt, that means less rust and corrosion on that steel part.
The Clamp bracket is easily installed and removed. We're talking minutes. Not so crazy easy that you would need to worry about theft. All of the mounting hardware is hidden from view and also placed in a counter bore in the Clamp to ensure the bolt head is never worn away or damaged by road debris.
*I'll continue to update this thread with detailed pics and the machining process. This is going to be fun!
Pricing:
Retail price for the AR | MAGNUM will be released soon! Like real soon!
BRONCO6G members are eligible for a 20% discount.
UPDATE: 8/3/22
Production is rolling on Pre-Orders!
MAGNUM Production Schedule
Order #Machine DatePowder CoatPost MachineEstimated Shipping Window
wk 110330-109756/30- 7/87/8-7/15TBD7/16-7/19
2778-28036/30-7/87/8-7/15
wk 22860-32197/9-7/157/15-7/22TBD7/23-7/26
7/25-8/2
wk 33226-32937/16-7/227/23-7/29TBD8/2-8/6
10683-10827
wk 43303-33288/1-8/78/5-8/11TBD8/11-8/19
10842, 10975, 2797, 2801
wk 53336-34668/8-14th8/12-8/18TBD8/18-8/26
3194-3210
wk 63542-36988/15-8/218/19-8/25TBD8/25-9/2
39833234-3393
wk 73734-38418/22-8/288/26-9/19/1-9/9
3479-3397
wk 83869-39428/29-9/49/2-9/89/8-9/16
3568-3827
wk 93943-39889/5-9/119/9-9/159/15-9/23
3843-3876
wk 104006-40889/12-9/189/16-9/229/22-9/30
wk 114107-41539/19-9/259/23-9/299/29-10/7
[email protected]
We are super excited for these to start shipping!!
Billnchristy
William
Georgia
Damn, delayed to Monday now! At least I don't have to worry about doing it before the Rolex starts now.
iBrad81
Brad
Cleveland
2022 Ford Bronco
When did you order by chance i ordered Black friday so hopefully mine ships soon
Billnchristy
William
Georgia
11/2 shipped 1/23
SgroiRoy
Roy
Western, PA
2023 Bronco & 2006 Ranger Sport Supercab
Finally received "scheduled for Production" E-mail from Ford!!
Send it!
Bruzer22
CO
1968 Mustang, 2022 Bronco
Send it!
Billnchristy
William
Georgia
Daylight shot
Ford Bronco AR | MAGNUM STIRRUP® Full Length Billet Aluminum Side Step for OEM Rock Rail - Bronco6G Exclusive Part PXL_20230131_122646142
