Automatic Transmission -- strange downshifting in neutral. Is it normal?
broncobase1
Lincoln
22 Bronco Base
I was in the mountains this past weekend driving in a traffic jam after the ski area closed. During an area of a slight downgrade I put the tranny in neutral and noticed some strange behavior. When I braked to slow down the transmission would make a clunk sound as if it downshifted. At first I thought I was hearing things, but it continued. Is this normal? I have not noticed this in any other vehicle before.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Is driving in neutral a new technique for going downhill?
I’ve never heard of this before
please enlighten us
Gassyjack
United States
Hmm. Maybe modern vehicles aren’t programmed to coast in neutral? You probably confused the computer.
broncobase1
broncobase1
Lincoln
22 Bronco Base
please enlighten us
I knew this would come up on this site! Did I ask when it's appropriate to use neutral? Of course typically it is not a good idea. This was a rare situation of a very slight incline and very slow speed, and in this unique situation coasting was the perfect speed without the constant gear hunting and throttle modulation. I'm also not advising it or saying it's right. If you disagree that's fine but the question is pertaining to the mechanical design of the transmission and why it differs from others.
swami37
Perhaps you should of gotten a manual trans
broncobase1
broncobase1
Lincoln
22 Bronco Base
This isn't a big deal and I'm not complaining, just curious why this transmission works this way. Neutral typically disconnects the engine from the driveline and there is no more involvement of the transmission, and this is the way it works with other automatics I have driven. It seems strange the tranny is shifting (or whatever that noise is) when in neutral . Overall this is a great transmission, aside from an occasional harsh downshift when braking. Just hope it holds up for the long haul!
Taltyman
Paul
Forney tx
Jeep wrangler Rubicon, Ford F350, Braptor
Doing a search I see other ford forums where people were curious about this. Some typical flaming about going to neutral. But some of the items discussed were cruise control, sports mode settings, engine protection, etc. Likely the computer is "helping" you.
HCGxKaLiBeR
Tom
Simsbury, Connecticut
2018 Audi S4
It should be smooth... My wild guess is there could be slight play on the U-Joints or gears in the transferase or transmission. When the rear wheels are slowing down, it clunks the drivetrain because inertia.
