- Mike
- Oct 5, 2020
- 13
- 624
- 976
- Franklin, MA
- 2008 F-350 reg cab srw v10 manual
- Badlands
Not a lot of photos out there of the lightshield pro, so either nobody cares or nobody has uploaded photos yet so here goes.
Price: $249.99
AVS has three basic types. Note there are a few more types without lights.
No lights
Marker lights similar to Raptor, but on hood
Pro lights w/ sequential turn signals
I went for the pro after watching a review that showed the non pro model to have a cheap light strip. Having installed the pro, I’m not sure there is any difference.
First step is to apply the light strip to guard with supplied tape. The issue here is the light strip ends have to bend quite a bit to meet the deflector surface. They don’t bend, so you wind up with the ends proud of the deflector. Not great, but I’m hoping it will be ok. If I have to I guess I can silicon the void and redo it all.
Next step is to adhere the deflector. Pretty straightforward, but two people would have been nice to help center and pull the tape liner. I wish the center of the deflector was marked to help out. and the leading edge extended a bit more to help conceal the wires and hood lip.
Wiring was straight forward, but I only hooked up an upfitter switch and ground. I’m not sure about the animated turn signals. There are two 8mm weld nuts above the aux wiring pigtails. I tapped both and used one to bolt a ground distribution block, and the other to terminate a 10ga ground lead to the block. I wrapped the wires in loom and ran it inside the hood to the hinge. A 1” square piece of foam tape is supplied to conceal the wires as they wrap around the leading edge of the hood. The foam immediately fell off.
If anyone is interested I can update with better pictures and videos.
Price: $249.99
No lights
