Back door rubbing on fender flare
RebelRebel
Ashley
Idaho
Acura MDX
Has anyone else noticed that the back doors on the 4-door bronco rub up against the fender? I fully wrapped it last week and the PPF is already getting damaged at that corner, which is great, since it's not the paint anymore, but I already have chips on the door edges that I didn't notice until after the wrap. Attaching a pic I took tonight, sadly it rained in the first time in a bit and kicked sand up from the roads, but helps to see that there is very little room between the door and the fender. Curious if others have noticed this. Thanks for the reply.
andrusoid
Steven
Bend, Oregon
2017 Outback, '79 2G, '89 3G, '92 5G White!
Ford Bronco Back door rubbing on fender flare IMG_3078
Have not seen that. I still want a tailgate, but the swingate is handy.
Bronco cat
Carl
Morgantown wv
‘20 Explorer ST, ‘19 GT350, ‘21 Bronco Sport
That is warranty right there. Make ford fix it.
RebelRebel
RebelRebel
Ashley
Idaho
Acura MDX
Bronco cat
Carl
Morgantown wv
My explorer had the hood and front bumper totally screwed up from the factory and my dealers body shop made it better than factory. Good luck man.
MeanGreen
Marco
San Antonio, TX
2014 Volvo XC90
And... That's the flare, not the fender... Right?
Can you adjust it?
RebelRebel
RebelRebel
Ashley
Idaho
Acura MDX
Can you adjust it?
Yes, the plastic fender flare and the bottom 1/2 inch or so of the door is making contact. I pulled the fenders and re-installed them, same issue. I think the molding is just off on the flare. My opinion, don't think it should be that close a piece of sand is bigger than the gap.
MeanGreen
Marco
San Antonio, TX
2014 Volvo XC90
Yeah, if you've tried adjusting and it's an issue, warranty fix. 👍
RebelRebel
RebelRebel
Ashley
Idaho
Acura MDX
