How should I modify the attached aftermarket fog lights wiring in order to connect it to aux switch? The harness comes with 3 pins/cables, while aux switch only has 1 cable.
Beat me to it, great advice, and correct!You only need 2 wires. Power comes from the Aux switch wire , the other to ground. No need for that switch or relay pictured.
The highest aux switch rating is only 30A, so if that number is correct you may need to wire in that relay. Seems crazy that those 2 little lights are 40ACutting it and connecting directly to aux switch seems to be the easiest option. The lights are rated 40A. Thanks guys!
"30A fuse & 40A relay" is what product description says. I'm not sure if it is 30A or 40A at this point lolThe highest aux switch rating is only 30A, so if that number is correct you may need to wire in that relay. Seems crazy that those 2 little lights are 40A
Do you have a link for the lights so I can look at the specs?"30A fuse & 40A relay" is what product description says. I'm not sure if it is 30A or 40A at this point lol
Lumimotor Flush Mount LED Pods w/Wiring Harness 2pcs 50W CREE LED Backup Lights Flush LED Light Bar Work Light Fog Lights Auxilary Bumper Lights for Truck Pickup UTV ATV SUV Trailer 4x4 Car https://a.co/d/bVVLb1rDo you have a link for the lights so I can look at the specs?
Okay nevermind. 50 watt is nothing. You should be fine using any aux switch you want without needing the additional relay.Lumimotor Flush Mount LED Pods w/Wiring Harness 2pcs 50W CREE LED Backup Lights Flush LED Light Bar Work Light Fog Lights Auxilary Bumper Lights for Truck Pickup UTV ATV SUV Trailer 4x4 Car https://a.co/d/bVVLb1r
