Looks fun!
It's just a resizable one off Amazon, link below. I wasn't brave enough to cut the RTR mat it came with. This one works well, though it's a soft material rather than the rigid mould of weathertech/RTR.What is that cargo mat that works with the molle panels?
Looks great!Looks great and love the RTR rims. They make some great products.![]()
I wouldn't upgrade tie rods. You are right about the fusable link.Did your BD start out with Squatch?
Also, probably a dumb question — but if your tie rods fail, it saves the rack. I see you plan to upgrade the tie rods AND also install the bushing kit. I’ve not done a deep dive but my question/concern is if the bushing kit (plastic) provides enough “beef” to keep the rack from getting trashed since the upgraded Icon tie rods will no longer be the fuse (weak link).
I understand it’s advertised to strengthen the rack, just curious from the perspective of real world abuse and not marketing mouths.
Thanks for confirming. Hate to see the OP spend money on tie rods that ultimately trash his rack.I wouldn't upgrade tie rods. You are right about the fusable link.
Bushings are totally fine, they will protect the rack itself.
Yep, SAS from the factory.I wouldn't upgrade tie rods. You are right about the fusable link.
FYI @Tricky Dick has a tie rod kit with tools and everything.I may actually do just do the bushings, return the Icons, and pick up a spare inner tie rod to carry.
Excellent. Just ordered, will be returning the Icons.FYI @Tricky Dick has a tie rod kit with tools and everything.
https://td-distributing.myshopify.com/products/bronco-6g-tie-rod-repair-kit?variant=44004231807230
I like it quite a lot, the lid is worth it to be able to fit things in their easier than the standard lid. I saw some other users say that it rattles but mine has not, no more than the normal bronco trunk rattles anyway.How is the deluxe cargo enclosure?
