Agreed, it's not the deciding factor for me either, but BL is slightly out of the range i was wanting to spend as well, so it just is a factor.I prefer the BD colors as well, but it isn’t a deciding factor for me.
Maybe just do a BB with the E-Locker and get a better set of A/T's in 255/75R17? I know it's not 33's, but it may not make much of a difference. It looks like there is probably vertical room for 33's but still need to figure out wheel offset and such.For my 2 exact same builds, the BL is $3.5K more than BD + Squatch. So I am paying more money for smaller tires and things I do not need (sway bar disco / front and rear steel bumper that increase vehicle weight).
You say 33s will ride the road a lot better, in which way?
2.3 I think.
Auto.
I am getting an ultra light 80 LBS RTT. No problems there.
A lot of people recommend to go BL non squatch, but if I compare a 2.3 Auto with mid package, the BD Squatched is $3.5K less than the BL. Also I am not a fan of the steel everywhere because they add a lot of weight and I am hauling lots of stuff when overlanding.
My ideal build is a BB with 33s and Squatch suspensions + the 4.27 ratio with rear locker + the 4A gear shift but this is not an option on BB. This build does not exist and I don’t like the idea of modifying the vehicle not from the factory.
Removing the 35s from a squatch is also not cool because 4.7 ratio with 33 is not ideal.
Anybody tried back to back the same vehicle with the same tires but one in 33 and one in 35?
BD comes with front and rear steel bumper as wellFor my 2 exact same builds, the BL is $3.5K more than BD + Squatch. So I am paying more money for smaller tires and things I do not need (sway bar disco / front and rear steel bumper that increase vehicle weight).
2.3 I think.
Auto.
I meant BB, edited my post sorry.BD comes with front and rear steel bumper as well
There is a significant difference in braking distance between 33s and 35s. 33s will accelerate much faster. Turning is affected, i.e. you would run a slalom course a lot quicker on 33s. All this results in better road manners for smaller tires. 32s will have comparable advantages over 33s. These are undeniable facts.For my 2 exact same builds, the BL is $3.5K more than BB + Squatch. So I am paying more money for smaller tires and things I do not need (sway bar disco / front and rear steel bumper that increase vehicle weight).
2.3 I think.
Auto.
A lot of people recommend to go BL non squatch, but if I compare a 2.3 Auto with mid package, the BB Squatched is $3.5K less than the BL. Also I am not a fan of the steel everywhere because they add a lot of weight and I am hauling lots of stuff when overlanding.
