Bronco G6+ Refresh Poll. What would you like FoMoCo to change?
  • Total voters
    295
The Pope
So... I've started this Poll. As others suggestion as to what other Refresh Items could be, I'll try to add them to the choices.
I'm unable to Edit Prior Choices, but I'm able to add new choices.
So... as an example....
-Heavy Duty Tow Package (please select this if you want 5000lb Tow Rating, Higher Tongue Weight Capacity, Air Bags or Heaver Capacity Springs)
@Ford Motor Company (added tag so that these "suggestions" will be "possibly" considered)
MorgansRun
Virginia Beach, VA
BMW 330e
Powered hard top. :ROFLMAO:
PowPow
PA
2018 Tahoe
hard to answer until the majority of us actually get Bronco's.
Mean Red GT
Kevin
TN
2022 4 Door Badlands/2016 Mustang GT PP
rtaylor
R
ID
19Raptor, 22Bronco
1 - winch solution with clearance, camera, and acc
2 - fix clearance issues for stock width 37" (front frame & rear fenders)
3 - improve 2.7L underbody brace (clearance/harden)
noliveaxle
john
Riverside, Calif
2015 jku rubicon
Tachometer that I can see. Please add.
Scohin
Ford Fusion
For MY22?
-Rear Console A/C vents (everybody else has these wtf Ford.
-Light interior options (2 options) on all Trims and Materials
-Digital Instrument Cluster update (The square and the bar motif is crap compared to Mustang and F150 higher options) Give us gauges again
Mid model refresh MY24?
-Hybrid
-5k lbs towing
-Internal material improvements ("cheap plastic" removal)
-Flat load floor
KyleQ
Kyle
Twin Cities, MN
8 Broncos!
I thought we were getting the 2.7 & MT next year but I REALLY want to tow 5k with the Bronco, everything is rated for it in the other vehicles that share the engine/trans/diff, I'm betting it's just a suspension compliant issue. If there were optional airbags to solve the issue that would be dope.
