- First Name
- Matt "Rusty" R.
- Joined
- Dec 17, 2021
- Threads
- 87
- Messages
- 1,582
- Reaction score
- 2,214
- Location
- Jupiter, FL
- Website
- www.instagram.com
- Vehicle(s)
- 2022 Ford Bronco Badlands Sasquatch
- Your Bronco Model
- Badlands
- Thread starter
- #46
Replies embedded below.
Thanks for posting this!
I recently bought a Charger 2 and Elite 100v2 and was just getting ready to install it.
A few questions on your install:
How long does it take the charger 2 to fully turn off when the vehicle is stopped? It will stop drawing power from your car's battery 3-6 seconds after the engine is shut off. It also has reverse polarity protection, overcurrent protection, short circuit protection, overvoltage protection and undervoltage protection - so your truck battery doesn't get jacked up.
I was thinking about running a D+ signal cable on the Charger 2 to an aux switch to have control of when it’s off and on. I had a problem with the Charger 1 never turning off and draining my battery while in standby on my truck. I haven’t read up on this enough to fully understand how it works, but my understanding its for interfacing with "smart alternators." Any special use beyond that - please share that all here may benefit.
Did you use 4 or 6 awg wire For the battery run? I used the 6awg that came with the unit.
How did you run it? Passenger side channel, driver side, or under? Driver side, through the firewall grommet, and down the main wire chase.
What shelf and Molle panels do you have? They're all Mountains2Metal - code RUSTYSBRONCO saves you 5%
I’m ready to do the same install, but have been debating where to mount the charger 2. Some people mount the Charger 1 inside the driver cargo panel, but I don’t think the charger 2 will fit. it fits in the rear cargo pocket or under the floor, but limits access. Big issue I had with choosing a location was the length of the proprietary cable for the battery provided by Bluetti. I reached out to customer service to find out if they sold a longer bidirectional cable, and they were as reliable as an outsourced 3rd party company as you would expect (hint - they weren't at all). Told me to go search Amazon for a proprietary cable that they manufacture.
My wife and I like to take the top off the Bronco, and I’m trying to avoid any molle panels above the cargo area. It seems like there are limited shelf options. There's a bunch of options. Mountains2Metal, Broaddict, Bison Gear all make them - just to name a few.
