Bronco Raptor Wheel Offset confirmation?
stumpm2
'67 Bronco, 2012 F350, 2019 Expedition
I thought the F150 raptor was 0 offset.
I was looking at fifteen52 turbomacs and it looks like they have them for the raptor but in ET0.
How would that sit on the braptor?
You will need to be careful with any wheels not matching the factory specs to maintain full suspension travel without interference. The entire wheel well, fenders, and flares were designed around the long travel capabilities of the Raptor suspension.
FellowM3
Northern NJ
Current: 22' Braptor, 2020 BMW M340
Agreed. Thats why im asking I basically want to keep the same exact wheel spec. I saw fifteen52 had 17x8.5s (same size) along with the right bolt pattern.
Now just trying to figure out the offset.
Raptor911
Raptor911
Raptor911
Broadlands, VA
If the Warthog wheel is +34 offset and you went to 0 offset then you are pushing the wheels out 34mm. 34mm is the same as 1.33858 inches.
I hope this makes sense.
0 offset is as far as I would want to go out.
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
For better or for worse, just about everything they make is 0 offset. Damn shame, I'd love a set of the Patrol HDs in the +20-30mm range
FellowM3
Northern NJ
Agreed. If bronco raptor is +34 offset, I wont go with these wheels. I want to keep stance stock. Im ok going with a ET30...but not all the way to an ET0
lewishamilton
Canada
17 VW Golf R
Your Foucs RS is beautiful. I am interested in the Turbomac HD for the Raptor as wel.
Couple years ago I saw Ken Block's Focus RS have them on and I fell in love with them.
MJJ
Sean
Iowa
JL Wrangler Rubicon, Jeep Wagoneer, Colorado ZR2
I will likely go with custom forged wheels from BC Forged. They can build them with correct offset and hub bore for a perfect fit.
Raptor911
Raptor911
Raptor911
Broadlands, VA
BC only makes 2 and 3 piece wheels for trucks right? I don't think they make 1-piece truck wheel.
Raptor911
Raptor911
Raptor911
Broadlands, VA
So there has never been any evidence that the Bronco Raptor wheel is +34 BUT finally, I found proof. I saw a Facebook ad for a set of wheels and one of the pics shows "ET 34" ... upper right in the image below
Ford Bronco Bronco Raptor Wheel Offset confirmation? 1674617316088
MJJ
Sean
Iowa
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
Went with RTR Evo6 17x9 +18. Wheels are 22-23lbs a piece. Stock rubber for now. Happy with my choice!
Ford Bronco Bronco Raptor Wheel Offset confirmation? IMG_0626
350vudu
350vudu
Cleveland, OH
2017 Shelby GT350, 2019 Ducati V4S Corse
How perceptible is 1.3 inches compared to stock? I ask because I’m installing wheel adapters in order to fit my Fifteen52 Analog HD wheels to my raptor when it arrives so I’ll be out close to 2in from stock 🤣. Seems that will put me even with the flares.
derichio02
Bo
Southern California
My RTRs I’m the post above are about even with the flares and that’s a 17x9 +18, compared to stock 17x8.5 +34, the RTR has about a little less than inch more poke. (22.4mm = 0.882 inches). 2 inches would probably put you past the flares.
350vudu
350vudu
Cleveland, OH
Do you have a closer pic of the wheels demonstrating the poke?
Either way I’m fine with being slightly past flares if it comes to it. I already have the wheels sitting in my spare bedroom and will do what I can to run them. Best looking wheels IMO.
