Bronco Team 2 door.
mpmcgaughey
Matthew
Houston, TX
2015 Ford F-150, 2022 Ford Bronco Wildtrak
Ford Bronco Bronco Team 2 door. 396E6382-1EB6-4081-BC30-595B3B34FA5E
jcgcbns22
Caleb
Nova Scotia, Canada
Almost done with my Bronco mods. My credit card will be glad for the break! 6,000 km so far. 1/13/22 delivery. 2.3L plenty peppy. Please with gas mileage overall. Roush exhaust fav mod so far. Lights and stereo in the queue.
Ford Bronco Bronco Team 2 door. 4E622883-7F57-4466-9FA8-D1393BCDC760_1_201_a
Koz44
Alex
Westchester County NY
2 Door Bronco Outer Banks
I lucked out on a freak 76 deg. Friday afternoon! Install wasn't too bad, until I got to the bow mounting. Got a little upside down and had to go back and fix it, as the illustrations could have been better. There was also a couple brackets toward the end that really kicked my ass, because about 12 screws were fighting me. That part took entirely too long, and if I did it again I'd run a tap through the brackets to clean them up. At the time I just let them kick my ass, and not sure how bad they'll be to remove. I did it all myself, so from MIC top removal to laying everything out, inventory of items, going over the instructions to final gasp and beer was about 5 hours. Not exactly the hour and a half they claim 😂. A helper would have made it faster, for sure. Also proper fitting screws 😂
What tools did you need for this? I saw another post with a list of the Torx bits used - were the correct Torx bits in the Ford kit or did you need Torx plus as well? Anything you ended up using that you didn't initially have on hand?
CMillBronco
Craig
2024 GMC HD 3500 AT4, 2022 Toyota Tacoma TRDORP, 2023 4Runner TRDORP
BradW
Brad
Gonzales, LA
2022 Bronco, 1933 Ford 5w Coupe
Have somebody sit in the back seat and shine a light above the roll bar on the right toward the front where the shell and front top meet. Stand outside and see how much light gets out. My seal is embarrassingly bad there... I can see the actual flashlight lens, not just the light! It needs to go to the dealer at some point but only leaks when pressure washing so it hasn't been a priority.
Thanks! I'll check it out.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
BradW
Brad
Gonzales, LA
Yep. Thats it. Not as bad as yours but I see light on the passenger side and none on the driver side.
rhymeswithbronco
Stewart
Spokane, WA
2023 2-door 2.7 Badlands
I'm picking mine up mañana too! 👌
Ford Bronco Bronco Team 2 door. IMG_0232
