I am looking to add softer camp lighting in the rear hard top hatch (not sure exactly where yet). I want to have red and white options depending if I am hunting or bugs are out or just tailgating. My idea is to use the @diodedynamics led strip kits. I want it all with manual switches so I did not buy the bluetooth option(but i'm considering it...) My plan is to run the factory aux switch back to the rear quarter panel wire and then split that into a 2 or 3 way switch that is mounted inside the bed. In doing this, I can set it to red or white using the rear switch and then only take up one factory aux switch and avoid running new wires to the back. Also, the engine bay kit from DD comes with plug in connectors(not sure what they are called), so I plan to position them so that I can unplug easily when I remove the hard top.
Anyone have any ideas, problems, recommendations that I am not considering? Also, has anyone used these light strips? i'm wondering if they are bright enough to illuminate the back without being blinding. Anyone know where to find a 3 position "either or" switch?
This is where I got part of the idea:
