Can 87 octane gas hurt my Bronco?
bronc'o
JC
CT
2021 JT Rubicon, 2020 Defender FE, 2022 Bronco WT
With the ridiculously high cost of gas these days, I was wondering whether anyone has tried 87 octane gas with their 2.7L Bronco.
I realize there are performance benefits with the higher octane options, but not sure whether 87 can harm my Bronco.
Any thoughts?
Roger123
Roger
VA Beach, VA
Answer is no, it cannot hurt your Bronco.
mybikeisred
Paul
Carmel, CA
F250 Powerstroke, Grand Cherokee
With a 10:1 compression ratio, you should be using higher octane fuel, but I think I read somewhere that there’s some sort of sensor that can tell if it’s running lower octane fuel and adjusts the timing accordingly to prevent engine knock. I’m not really sure how that works, I thought engine knock was from premature combustion before the plug even sparks.
VVSidewinderVv
Tim
Pittsburgh, PA
20 GMC Sierra
It is. Higher octane resists preignition better. Advance timing allows the fuel more time to mix and vaporize, thus making it more efficient at producing power. Retarding the timing gives the fuel less time to preignite but also less time to mix for the most efficient burn.
Techun
Pa
BD, 2.7, MIC, 4dr
No
Opticnerve19
New Jersey
Infiniti qx60
Any thoughts?
What does the owners manual recommend ?
Broncodave
Seattle
Dodge Challenger/Nissan Xterra
TheKim
Kim
Running 87 will only hurt your Broncos feelings, not its engine. :(
tyrobronco
CC
Central Florida
2021 Bronco,2017 Ford Fusion Energi
Any thoughts?
As others have said, the owners manual says it can take 87 octane.
If you are towing or off-roading, the same manual recommends 91+ octane as it gives the engine greater HP and torque.
PartyMarty
Marty
2016 Jeep Wrangler Black Bear, 2009 VW Rabbit
87 won’t hurt anything, we just lose 15hp and small 5-10% efficiency gains. That garbage 85 octane they serve you as regular in CO will mess up your engine though. I’m amazed rental car companies in Denver rent out boosted engines and don’t have any warning saying fill up with minimum 87 octane.
