Can you put a Wildtrak bumper on a Base Bronco?
ibock
Dallas
2022 2 Door Bronco
Can you put a 2023 wild track front bumper on a 2022 base bronco?
Nogame24
Denver
Front or rear and which one - modular HD or capable?
MNBigfoot
MN
Yes, but you either have to cut off 2 recivery hooks off your Base, or buy 2 new support brackets. If you are remotely capable, just cut them off.
Nogame24
Denver
Front capable
I did this on mine. As previous stated you need to cut off the tow hooks. Took me 5 min and then covered them with undercoating paint to prevent rust. Hardest part of mine was swapping the wire harness but you probably don’t have that. It’s really easy.
BigBend530
Dominic
Oroville, CA
2022 Ford Bronco 2Dr.
Just swapped standard bumper with capable bumper on Big Bend. Was able to get correct intercooler brackets with bumper purchase. Had to install wiring harness from original bumper for fog lights.
The swap is very easy to do.
ibock
ibock
Dallas
2022 2 Door Bronco
Do I need to get a wire harness if I have e a base bronco? IS there a tutorial to help?
