DIY Undercoating with CorrosionX anti-rust & corrosion spray
RDTC
Bob
WI
Ford F350, Jeep Wangler Rubicon, Bronco Outer Bank
Undercoated the Bronco this weekend. Total time about 4 hours. I work slow.
Removed the tires and skid plates. Used Corrosion X HD product. Purchased the 1 gallon size from Amazon. Applied with Harbor Freight pressure pot sprayer.
Results look good. Good control during spraying. very little over spray.
Will see how long it lasts.
Ford Bronco DIY Undercoating with CorrosionX anti-rust & corrosion spray tempImage4i4t94
Ford Bronco DIY Undercoating with CorrosionX anti-rust & corrosion spray tempImagelXc3bZ
Ford Bronco DIY Undercoating with CorrosionX anti-rust & corrosion spray IMG_1828
Ford Bronco DIY Undercoating with CorrosionX anti-rust & corrosion spray IMG_1827
Ford Bronco DIY Undercoating with CorrosionX anti-rust & corrosion spray tempImageEHlOCT
Ford Bronco DIY Undercoating with CorrosionX anti-rust & corrosion spray tempImageOS9Ugo
Ford Bronco DIY Undercoating with CorrosionX anti-rust & corrosion spray tempImageVocmri
Ford Bronco DIY Undercoating with CorrosionX anti-rust & corrosion spray tempImageuLqiO8
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Very neat!
SuperDave150
Lubbock, TX
Ford F-150, Ford Edge
@RDTC Kudos on job well done!
Dumb question: How long do you expect it to last?
