JKommuter
F250, Escape
I built myself a winch bumper. I wanted one that didn't block the intercooler and doesn't stick out too far. I have a 2 door base so not worried about cameras. I intended for it to be as light as possible. Not sure I accomplished that at 95lbs. I used 2x4 rectangular tubing, 3/8" plate, a Harbor Freight winch plate, and a Barnes Off-road bull bar. Painted with Rustoleum self etching primer, and "truck bed coating". Total materials cost was $350 not counting consumables (welding wire, gas,i Grinding disks, etc...). OK on to the pictures.
Ford Bronco DIY Winch Bumper Build Raw edited
Ford Bronco DIY Winch Bumper Build Test Fit Raw
Ford Bronco DIY Winch Bumper Build 20211123_121850
Ford Bronco DIY Winch Bumper Build painted edited
Ford Bronco DIY Winch Bumper Build Done Edited
Ford Bronco DIY Winch Bumper Build angle edited
Ford Bronco DIY Winch Bumper Build Close edited
JKommuter
JKommuter
F250, Escape
Forgot to mention, I wanted it to be bolt on, and it is. It uses the 6 bumper bolts, and picks up a bolt using existing holes in the frame rail about 5" back for a total of 8, 4 on each side.
Hey19
JJ
Bethlehem
Looks great! Well done!
webspoke
Stan
Pilot Point, TX
F450, GT350
Well done, simple and functional.
Bschurr
NY
Well done - nice skilz!
FootPain
2021 Bronco BB 17 Explorer 04 Mach 1 98 Explorer
That looks great. I'm a big fan of self made things.
drive21bronco
North East USA
2021 Bronco Black Diamond
Simple, effective. I like it
MaverickMan
Shane
Nice Love it. I build my own bumpers too. Buying stuff is never what I want it to be, Mine will be similar but I want to sink 4 vertical posts to it, at the ends and at the bends. The 2 in the middle I will connect(replacing the bull bar) and the ones on the ends will be freestanding but strong enough for throwing a rope over as long as the pull is downwards enough. Also makes wrapping a strap easy. Great job on yours. Any plans for lights on it?
PDiddy
Paul
4Runner
Looks awesome! I’m doing something similar out of wood and PVC. Just kidding… I can can bolt things on, but I can’t build what I bolt on.
  • Like
Reactions: R11
JKommuter
JKommuter
F250, Escape
I will eventually add some lighting. No solid plans yet. I'm currently trying to decide if I want a 1" leveling kit to compensate for the weight of the bumper and winch. It sagged at least 1/2". I am also thinking about a "bash plate" under the bumper to replace the plastic air dam thing on there now.
MaverickMan
Shane
Nice. I would wait on the level till you decide you love the front bumper so much you want a matching rear. But i am always against levelling kits. Unless you got a plow :ROFLMAO:. Dont forget you can make that bumper an air tank if you got a compressor on board.
Lab00Rat
MS
2022 BL 2-Door, 2021 Ford Ranger
Looks sweet.
Great Job!
jonesh242
Southern Cal-unicorn-ia
Cherokee Trail-Squak, YT Capra 29er & Decoy Mullet
Bravo!...well done. I like the minimalist design.
