- Fraser
- Mar 20, 2023
- 6
- 136
- 204
- Orange County, California
- BMW e92 328
- Wildtrak
Thanks for the kind words. It is a little beast isnt it. Modern class D is very impressive.I thought I’d update this thread since I originally found mObridge from this forum.
I just installed mine and what a little beast.
Fraser was super helpful when I had questions.
I am running all the speakers from it plus an aftermarket sub. The DSP software is top notch and even allows presets to be controlled through the speed compensated volume.
I still need to tidy up the power run but all good so far.
I was going to run a separate sub amp but this powers what I have with no problems.
Units case is built really well and the harness is really nice.
The only surprise is there doesn’t seem to be a fan in it and there are no passive cooling fins because she gets pretty hot, probably not a big deal. It’s doing a lot.
I recommend.
So on the heat front. The D class chips we use are automotive grade and a rated to run up to 120c. They will usually idle around 65-75C. All parts used in the amp are automotive rated and are also rated to run up to 120c. We have numerous over temperature protection features in both software and hardware if we do find ourselves getting too hot the amp will protect itself.
