Dune Flag
Acadist
WA
2023 BadSquatch
Installed the Swarfworks dune flag mount today, great fit and finish
Ford Bronco Dune Flag IMG_2501
Ford Bronco Dune Flag IMG_2502
Ford Bronco Dune Flag IMG_2504
Acadist
Acadist
WA
2023 BadSquatch
And here I was hoping for some cool Atreides or Fremen flags :crazy:
Wait till you see me jump on top as my wife is driving
bellboyfab
So-cal
‘22Bronco ‘93 C3500
Dose that flag base fit thru the hole thats under those end caps on the mod bumper.
Bronc6g22
Jake
Washington
Mazda 6, Tacoma TRDOR
Built my own mount. Works great with just the two bolts as well.
Ford Bronco Dune Flag 20240412_182045
Acadist
Acadist
WA
2023 BadSquatch
Didn’t want the pole rubbing against the body panels
Acadist
Acadist
WA
2023 BadSquatch
bellboyfab
So-cal
‘22Bronco ‘93 C3500
Understandable. I'm just Genuinely curious about that flag Quick connect flag base and flag
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I was actually wondering if your setup allowed for the flag to rub on your body panels, but I’m assuming not? I’ve never used a dune flag before, but I thought at high speed that pole would bend every which way 🤷‍♂️
Acadist
Acadist
WA
2023 BadSquatch
Probably could with modifications, since I have lights in n the pockets longer bolts would not work. It is designed for the top and has a neoprene gasket between the number and the mount.
Acadist
Acadist
WA
2023 BadSquatch
My concern too, the mount goes out to the outside edge of the fender flare and is 1/4 steel so it won’t flex, that was my other concern.
APEX REX
23 Braptor and 21 2D Base 2.7 SAS
FYI: Use a pool noodle over the flag shaft to protect the vehicle. It works perfectly.
