External Ambient temp failure turns off stop start. Think I’ll leave it. 🤷🏻‍♂️
bkfit
BK
Spaceship
Ford Bronco External Ambient temp failure turns off stop start. Think I’ll leave it. 🤷🏻‍♂️ 605FEDB5-2523-45C1-80DE-F8AEE2B81E87
Bongo Fury
Bongo
Somewhere between point A and point B
2003 Ranger
bkfit
bkfit
BK
Spaceship
WuNgUn
Ontario Canada
2 door Squatched
Thanks, She’s scheduled & going in tomorrow
Morning. To get looked at…
Yeah, apart from possible engine function, it'll mess up your HVAC as well. My messed up sensor wants to turn the AC on in auto mode when it's -20 outside!! Anything other than HI temp blows cold air.
Let us know what they find.
I assume you're getting the same cold temps in Michigan that were getting here in Ontario.
The sensor seems to malfunction in extreme cold.
bkfit
bkfit
BK
Spaceship
Thank you kindly for the feedback. Yes it’s cold, the day it went check engine was -4deg Fahrenheit. Or -20 Celsius (I think math is hard)
WuNgUn
Ontario Canada
2 door Squatched
Mine acted up Friday night... -25C
By the time I got home from work, it said it was a balmy 40 degrees out!
Wasn't as inaccurate today, but still went into the +'s
It'll thaw out by Tuesday... See what it does then.
But since I picked it up, it always been off 2 or 3 degrees.
bkfit
bkfit
BK
Spaceship
Do you plan on taking it in for service? Or rocking her as is?
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
I had the same service light come on. Did you by chance remove your side view mirrors? There is ambient sensors behind the mirrors and mine thru a code after reassembling the side view mirrors. I flashed the code and it never came back
bkfit
bkfit
BK
Spaceship
Interesting, I did have a driver side mirror crack without contact, (supplier issue)is the sensor in passenger or driver side? I haven’t taken off my mirrors. I did unplug battery to clear it before I knew what it was via ford app alert. It’s 20deg outside and it’s reading 65-70deg Fahrenheit.
@BadBlueBronco
Kc
Los angeles
Im not sure which side they are on.
WuNgUn
Ontario Canada
2 door Squatched
Probably gonna phone the dealer today... It was acting up again yesterday.
When I got in to it after remote starting, the AC was on. Likely not good for the compressor!
WuNgUn
Ontario Canada
2 door Squatched
I haven't had a service light with mine... And the ambient temps moves around. Started at -9 yesterday and crept up to 16 degrees 🤷
bkfit
bkfit
BK
Spaceship
Update, Its the A
Update, took her in to dealer, they said exactly what was shown on app, its ambient temp sensor failure. None is stock so they ordered and will replace complete driver side mirror. Does not effect engine, was stated.
bkfit
bkfit
BK
Spaceship
