- Thread starter
- #1
Hey All,
Just got back from a trip to Missouri from San Diego. Did a lot of research on flat towing my bronco. How to engage it properly, how to disengage it properly, and what causes failure. For the most part it seems battery drain is what was the main culprit. I added a hot lead off my coach to the battery to maintain charge for the long days of travel. Well, on the last leg back to SD my coach broke down in Pheonix. We sat for a bit and during that time my wife took the bronco to a friend's house to grab a scanning tool. She returned, I hooked the bronco back up when the service tech was finished getting the RV back up and running. We pulled off the dirt shoulder, saw the Bronco was turning and wheeling freely and hit the road. When we got home, i disconnected the Bronco and started it up. I instantly got a stop engine, coolant too hot. Shut it off, let it cool for a little, smelt burnt engine oil and looked under the hood. No leaks, so I started it back up. Same warnings came on but this time I tried to put it in gear to see if I could move it out of the way of the RV. The Bronco just jolted in place like the torque converter wasn't engaging. I'm guessing the transmission and motor are toast. Before I go to the dealer, I'm just curious if anyone else has had this issue and any luck with Ford/warranty. My insurance Broker says he thinks he can get it covered that way but all the posts I've seen (short time I have been looking) have been a few years back and/or seem to be just confirming it's an issue and not anyone that had directly had this issue. Thanks in advance for any feedback.
