Flat Tow Test w/ Issues (Help Please)
edwinroark
Ed
Georgetown Tx
2022 Bronco
I run the blue Ox system with 2.7 auto follow manual and tsb, have 18 different days of towing and unhooking without a single glitch.
I did print instructions and follow each step.
I have talked to few fellow RVers that were surprised it works as they have read from too many doms dayers on this forum that had them believing you cannot tow with brakes.
Let the flaming begin again. 😆
Wondering if you are still having great results with your 2.7 Bronco as a toad?
Berggie
Ken
Minnesota
Badsquatch, EV6
Yes no problems as of now, RV put away for the winter.
Runyon
CA
2024 BL, 2.7, SAS, 2dr, Lux, Rack,tow.
This is the New software feature that disables the brake it throws all kinds of brake errors, once in tow mode you should pump the brakes a few times before you put on the RVI brake assist. It will pop up then too.
TerryVester
Terry
Ohio
2022 C8 Corvette, Jeep Wrangler, Linlcon
I have the same brake light problem to after towing. It always goes away after I drive it. My brake is a NSA Ready Brake - surge brake. I think its a ford brake peddle problem the computer does not like the peddle being pushed with the vehicle off.
