bpesto
Orange County, CA
Audi, RAV4
BTW, Blue Ox has another style that does require slight trimming of the plastic on the Modular Bumper. I like the way the safety cable bracket is here. The ones that angle down might be bent up with a pretty good tug on them, especially with the shackles in them that could increase the leverage.
See attached.
xcntrk
xcntrk
NOVA
22 Bronco Badlands 2dr
Pretty clean install on the base plate.
I've got the modular bumper and want to mount the Blue Ox baseplate. It looks like it's just a bolt on setup (after removing any parts to gain access for the install). Was there any trimming of anything with the mod bumper. And can you confirm the Blue Ox part number for the base plate?
Yes, you have to trim the inner plate behind the mod bumper. You’ll want to check the BlueOx website for the latest baseplate part number. Looks like they have 2 different versions depending on dynamic cruise control.
xcntrk
xcntrk
NOVA
See attached.
Ford Bronco My flat tow setup w/ Blue Ox baseplate, Assent towbar, Patriot brake system, direct wired brake lights Baseplate Option
That is actually an older design. The new version has the breakaway mount sticking straight down. It sticks out beyond the bumper in bother versions
NC_Pinz
Central NC
OP, any follow up on using the Patriot Brake system? We're a few months out from purchasing our RV and I'm digging into what braking system I want to use. The Patriot is a little pricey but I like the idea of not having to tie or cut into any systems.
xcntrk
xcntrk
NOVA
It works and the remote controller is really nice, but I definitely wouldn’t buy it again. It’s strictly inertia based as an ONLY source of brake engagement. I’d rather use surge brakes! Other units use 2 or even 3 sources of brake engagement.
NC_Pinz
Central NC
Great feedback. I know that unit was pricey. I still have time as we haven't bought the RV yet. I have been looking at the Ready Brake surge brake set up. That has some appeal in not relying on electronics. I'm not keen on having the actuating cable sticking out the front.
dgorsett
colorado
F250, Mustang, Explorer
Just another opinion: I use the RVI which is also an inertia system, and am very happy with it.
NC_Pinz
Central NC
OP, another follow up question. The Blue Ox diode kit...did I read the instructions correctly that you needed to cut the wiring at each light and integrate the diodes and wiring? Are you happy with the results?
BTW, I decided to remove my recovery points (MOD bumper) and go with Blue Ox connection points like you have. I know they can be reinforced but I'm erring on the side of caution until I see something from Ford that says its OK to use for flat towing.
dgorsett
colorado
I use the Curt 58996 which is plug and play for non LED, they have 58992 which is for LRD. My kit came with an auxiliary pig tail that can be used to set up trailer wiring as well using a Curt kit.
NC_Pinz
Central NC
Thanks. I picked up the LED version and will install it over the holiday weekend. The remaining things to figure out are what the umbilical will look like and tying the Curt kit into a plug. I also want to set up a battery charging circuit to keep the Bronco battery topped off.
BigRed
Tom
Killbuck, Ohio
2023 Wildtrak
Does the dash power port stay on when flat towing? Worried that power from the dash power port would time out leaving the brake suddenly inoperable?
BigRed
Tom
Killbuck, Ohio
2023 Wildtrak
I have a 2023 Outer Banks with LED lighting and was wondering did the Curt #58992 work for you? Read several reports on Amazon that the harness didn't work on the Bronco? Etrailer also has notes that they can't confirm proper application or Fitment on Bronco??
Thanks
NC_Pinz
Central NC
Thanks
I actually didn't install it as I've decided to go a different route. I decided to not use my Bronco for flat towing and instead picked up a dedicated vehicle for that.
If you decide to go that route, I've got it still boxed up sitting on my bench in the garage. I'd be willing to let go of it for less than what I bought it for. PM if you'd like.
