Flat Tow Wildtrak
Broncold
Savannah Georgia
4Runner, wildtrax ordered
Hi, I have a problem that I can't find any information on, I purchased a E-trailer towing kit 38955 to install on my Bronco. I got the wiring and the diodes installed and when I went to test (without connection to the motorhome) the passenger side blinker is flashing really fast but all the exterior lights are blinking a a normal rate. All lights work signal, brake, marker and backup. Is there a relay that controls the turn signal lights if so where is it located?
Has anyone else experienced this issue?
SuperDave150
Lubbock, TX
Ford F-150, Ford Edge
Oh my. UNIVERSAL. Ugg.
I have a good friend with a Masters degree in Electrical Engineering and he flatly refuses such endeavors on automotive wiring. I agree.
I doubt that you’ll have a good day getting this universal kit to work.
I humbly suggest that you carefully remove it and start over with the custom kit from CURT. Be sure to select “WITH LEDs”
That’s what I used and it has been flawless.
https://www.curtmfg.com/part/58992
Broncold
Savannah Georgia
Thanks for your input.
grtharris
Grant
Skiatook, OK
Outer Banks 4dr, 2008 Mustang GT CS (Wife's), MH
I used the Blueox universal kit which is the same as the one you used and have not had any issues. Double check you wiring. Attached is the Ford tail light drawing.
Don't understand " but all the exterior lights are blinking a a normal rate "
Are the motorhome turn signals blinking normal and it just the Bronco blinking fast?
Broncold
Savannah Georgia
Thank you Grant this information having an actuals wiring definition helps, now I can verify my wire connections.
Hammer21
Glasgow, KY
‘21 Bronco, ‘16 F-150, ‘68 Mustang
I got tired of fighting it and let the dealer figure out why that was happening.
