Fuses powered by ingition
JC2DR
Joseph
Maine
Bronco Base 2dr 2.3 7speed
I apologize in advance for even asking this question. I looked for it but couldn’t find the answer.
I have a base without aux switches. I’m adding a Trigger 4 so I can add dis and a thing or two later. The power wires are red, black and yellow. Easy to understand. I want to only power the lights when the ignition or accessory is on. The yellow wire. I want to tap a fuse that is on with the ignition. I have aux fuses that are unused as well as power seat fuses. Not sure if they are powered? If so I can use one. If not I need to tap. Anyone know before what surely will be potentially messy trial and error?
Also, can I run the red wire to the “+”terminal off the fuse box and not the battery directly?
Thanks for all you can do.
SwampCactus
2022 4 Door Cactus Grey Badlands Sasquatch
I've used a fuse tap to get 12v power and hard wired in to charge my Bluetti as well as through the inverter (duel charge). I'm planning to change it from an accessory power to ignition power so need to see which one works good for that.
But here is a PDF showing all the fuses and what they are for.
Badsquatch2021
Chicago
Tbd
I was able to use a fuse tap on the heated steering wheel(37). Given it's high amp rating and I don't have it as an option I felt good about it. It comes on with ignition.
JC2DR
JC2DR
Joseph
Maine
Thanks for this! It’ll help me greatly.
JC2DR
JC2DR
Joseph
Maine
Thanks. I attack all this tomorrow. Looking forward to it all.
Johnny Mo
Westchester County, NY
teachu2shoot.com
M-B GLE53 AMG, Ducati XDiavel, Jeep WK GC x3
For the "empty" spare fuses has anyone confirmed that they are active? Looking for an ignition powered 12v for onboard air.
Texasgrillchef
Gary
Dallas, Tx
Bronco Badlands, Harley Trike, Mustang
Great thanks but it still doesn’t show which fuses are only powered on when the engine is running, or only powered when you push the button. As my bronco has remote start, and not everything comes on until you push the start button. I don’t have any test equipment to test what’s powered on and when.
trying to get information from someone who has the test equipment and has tested every single fuse Location to see which fuses come on when u remote start, when you have it turned on fully, and when u push the button without having the brake pedal depressed.
Example is number 2 fuse of the engine fuse compartment is that one only on when the ignition is on, or is it on full time? It’s for the power windows, ac/dc converter. Ok great. But is that always on, or only on with ignition? Etc…
