Grille Swap Camera Question
StachioAttack72
Paul
Connecticut
Bronco 4 Door Outer Banks
So I’m swapping my OBX Grille for a Badlands one. I’m wondering since I have the front camera, the new Badlands grille seems to have holes for the camera mount but I’m wondering if I need to order an extra camera bracket part as it seems to sit (along with the wiring) on a bigger mount than just the small camera bracket.
Am I able to pull off the bracket from the OBX and install it on my Badlands? Or did I miss an extra part?
the Badlands Grille Part that I have is:
M2DZ-8200-EAPTM
BroncoPls!
Austin,TX
23 Rivian R1S, 22 Bronco
You should be able to pull everything you need off the OBX to mount on the BL.
t_liz92
Tom
South Jersey
2022 4dr Bronco
Once you disconnect the wiring and water line to the camera, the camera will still be attached and come off with the grille. You can remove the camera housing and bracket for reuse from there but keep in mind your obx camera housing will be gloss black while the housing for the badlands should be matte grey. If you want it to match need to get the matte camera housing as well.
StachioAttack72
StachioAttack72
Paul
Connecticut
Once you disconnect the wiring and water line to the camera, the camera will still be attached and come off with the grille. You can remove the camera housing and bracket for reuse from there but keep in mind your obx camera housing will be gloss black while the housing for the badlands should be matte grey. If you want it to match need to get matte the camera housing as well.
[/QUOT
Yep, I’m getting stuff painted all gloss black.
