Grille Swap Letter Question
StachioAttack72
Paul
Connecticut
Bronco 4 Door Outer Banks
Ordered a Badlands grille for my OBX and I can’t really tell if the kit comes with new Bronco letters or I just pop off the one’s on my OBX and put them in the new Badlands grille? Anyone have any insight?
BitterBronco
Connecticut
2014 Tuxedo Black Ford Edge
The letters are fixed onto the grille (non-removable) so you should get them pre-installed onto the grille, I believe.
disclaimer: I don't have my Bronco - I looked into replacing the R on my Badlands with a red R (didn't want a sticker) and this is what I learned in the process
shoelessjoe
2013 Chevy Cruze
I don't think they come with letters when you order the grille from the dealership.
KPLOBX
Kristopher
Savannah GA
Jeep Wrangler TJ
You ordered from dealer? How much did it cost?
bb21
Chicago
2023 Ford Bronco Badlands, 4dr Oxford White
How did you order? Also, do you know if the grille will come in Badlands gray or will it need to be painted? I also want to do this but couldn’t find any info on ordering a grille.
Ducati1098
The letters are removable and do not come on a new grille from Ford. They must be ordered separately and then put on the grille, or very carefully removed from the original grille then swapped over.
Ducati1098
If you order a grille or anything else from Ford, it will not come painted.
Papa Smurf
Jax, FL
‘23 Bronco WT. ‘23 Maverick. Hybrid. '23 Rav4
The letters are NOT included. The BL/WT grille comes unpainted in a matte black finish. I know both of these because I have one sitting in my garage.
Ducati1098
The letters are plastic welded onto the grille. You can reuse you’re original ones if you’re careful about it, but you’re probably better off buying new letters and then installing them onto the new grille.
BitterBronco
Connecticut
That’s excellent to hear! The first couple I saw had them heat-glued to the grille so I gave up on the Red R. I didn’t want to go with a sticker over top
thanks for the tip!
