Dang! I've been doing it wrong all these years!!!The outside air is typically made up of 78% nitrogen, so just fill up your tires as normal, but then take out about 20% of the air and you should be left with just nitrogen in your tires. Oxygen is heavier than nitrogen, so position your valve stem at the bottom of the tire to more effectively drain the non-nitrogen parts.
