- RP
- Oct 17, 2021
- 0
- 25
- 30
- Los Angeles, CA
- N/A
- Wildtrak
Can I get a quote for the Dominator D6, 4-door? Please and thank you!
Sending quote nowCan I get a quote for the Dominator D6, 4-door? Please and thank you!
Pm sentHappy STEPtember Bronco6G!
We are proud to offer a very special deal for you all this month! We have partnered with N-Fab and Go Rhino on this one to bring you some outstanding steps with unbeatable pricing!
Pricing is going to be by PM or email only to take part of this huge sale!
I am going to highlight a few of our top sellers but if there is another N-Fab or Go Rhino board or step that you are interested in please don't hesitate to reach out as this discount does apply to their entire line! We specifically chose these two brands to work with due to the quality of their products and the ingenuity their steps offer
We will be running this special for the month of September, as the name suggests, so do not wait to take part in this limited offer!
(click on the image to bring you to the product page for more info)
While these options are only available for the 4 door models we do have some options available for the 2 door models on our site that I would be more than happy to assist with as well - https://realtruck.com/c/exterior-accessories/nerf-bars-running-boards/v/ford/bronco/2022/
2 Door options for Go Rhinos that are NOT currently listed on our site but are available are; 4" OE Extreme, 5" OE Extreme, Dominator D2, Dominator D6, Dominator DS, Dominator DSS Sliders, Dominator D1, V - series V3, RB10 Slim and regular, and RB20 Slim and regular
Go Rhino D1
Full-length drop down step
Protects rocker panel from trail obstacles and road debris
Great for accessing vehicles for lift kits and oversize tires
Uses OEM step and rock rail mount locations
6” wide
No Drill
5 Year Warranty
Go Rhino Dominator DSS Slider
Full length slider with outer rub rail
Removable full length steel step
Great for high clearance use when step is still needed
Protects rocker panel from trail and road debris
Easy installation, no drilling required
4” wide
5 Year Warranty
Nfab Textured Black
Main bar fits high & tight to the vehicle body
Patented drop down step design and location is engineered to allow easy access
3" diameter .084 heavy wall steel main bar allows for a strong and stable mounting
5 year warranty on finish and limited lifetime warranty on workmanship
No drill
NFab Trailslider
Designed and tested for the ultimate in protection - Fully welded and gusseted one-piece design
Compact mounting system - lessens the chance of hang ups and tested to have less flex
Primary tube dimensions: 2” x 2” x 3/16” wall thickness, accompanied by 3/16” thick steel plate gussets
13-gauge wall outside tube with steel gussets
Made in USA
NFab Predator Pro
100% Aluminum Construction for long-lasting durability and corrosion resistance in the toughest environments
The engineered aluminum extruded main bar with aluminum end caps fit tight to the body creating the ultimate in clean style
Patented drop down hoop step with new larger step area for ease of access for stock or lifted vehicles
Dimpled 4” step pad for secure footing in any condition
Fully welded 1-piece design for strength and ease of installation
No drill
Late to the part, but can I get a quote on the GoRhino Dss 4 door sliders?Sorry for the delay, had some connectivity issues due to the hurricane
Working on getting everything caught up, have extended this to Thursday
Late to the party, any left over deals on the Dominator DSS? - 2 door. ThanksHappy STEPtember Bronco6G!
Go Rhino D1
6” wide
No Drill
5 Year Warranty
4” wide
5 Year Warranty
Nfab Textured Black
No drill
NFab Trailslider
Made in USA
NFab Predator Pro
No drill
