Height of Hood with Struts installed
Moxie
Pennsylvania
2019 Vw Golf R
Would some kind soul who has the hood struts measure how much higher they make the hood ? I guess what I'm asking is would i be able to reach high enough to close it without grabbing the hood from the side. It's non-SAS and no lift kit. I open the hood every day for work and would love to install the struts. However, not sure if i could reach it. :):rolleyes: Im 5' 8". Thanks....
Lifeliberty
Moonbeam👀
Columbus, OH
Wallyworld Ranger 269
NJ
2014 Charger R/T
5’10” I just put the IAG struts on last Sunday, you should have no problem. Word of advice, after installing, when opening the hood, keep your hand on it. Don’t let the hood fly open.
Mlarv
TN
2023 Bronco/ 2022 F150/ 1968 Mustang
Howdy. If it is an issue, use a small strap to reach up and pull down on until you can grip the hood.
Moxie
Moxie
Pennsylvania
2019 Vw Golf R
Great idea !!!!
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
i'm 5'8" with a SAS Badlands. no issues closing the hood after the strut installation. (although my arms might be longer than yours)
BadlandsJ
2022 Badlands Non-SAS
I have the Ford Performance hood struts. From the hook on the latch to the loop under the hood is 37.5 inches.
Ninjak
Miami
2021 GT500 2021 Bronco Badlands 68 GTA
I will contribute and say you should be able to reach the locking latch to pull down. I have MRT struts and also an ADV hood.
I cannot comment on the reach any better because I am 6-41/2 :ROFLMAO:
TEAMSLO
NV
youtube.com
23' Bronco 2.7 4d Oxford White & 22' JLURD
I have the 23 wildtrak and installed the redline tuning quicklift plus (non max system) and at 5' 7" no issue reaching up and closing the hood.
Mike T
Brandon SD
2023 Ford Bronco
I am 5’10” with the FP Struts on SAS Badlands and it is up there but I can reach it. Redline makes the Ford performance ones so if concerned, like mentioned above, get the standard lift ones and not max lift ones from Redline and you will have no issues.
Rydfree
Benny
Alabama
Ford Bronco Height of Hood with Struts installed jum
Redline Tuning
F-150
Redline Tuning is pleased to be a sponsor on the Bronco6G forum and want to showcase our 100% Bolt-In Hood QuickLIFT system for the Bronco. Our system is the ORIGINAL Bolt-In system for the Bronco and installs in less than 10 minutes with no modification required to your vehicle or for you to un-bolt you hood to mount any brackets. We offer two different lift heights for the Bronco. Our standard QuickLIFT system raises your hood to the same height as the factory Prop Rod and our Max Lift system raises the hood 8 inches higher for maximum access to the engine compartment. Both systems are available in PLUS, Carbon and ELITE versions as shown below.
QuickLIFT PLUS features:
* All black powder-coated mounting hardware
* Black e-coated gas springs
* 4 year warranty
available directly from our website here:
QuickLIFT (same height as stock)
https://www.redlinetuning.com/2021-Ford-Bronco-Hood-QuickLIFT-PLUS-p/21-11040-02.htm
MaxLift (8" higher than stock)
https://www.redlinetuning.com/2021-Ford-Bronco-Hood-QuickLIFT-PLUS-p/21-11039-02.htm
QuickLIFT CARBON features:
* Black e-coated gas springs with real carbon fiber sleeves
* 4 year warranty
To add the Carbon option check the box show below on our website:
QuickLIFT ELITE features:
* 316L Stainless Steel gas springs
* 5 year warranty
https://www.redlinetuning.com/2021-Ford-Bronco-Hood-QuickLIFT-ELITE-p/21-11040-03.htm
https://www.redlinetuning.com/2021-Ford-Bronco-Hood-QuickLIFT-ELITE-p/21-11039-03.htm
Free shipping in the CON. U.S. on all Bronco systems using coupon code "Bronco6G" at checkout.
You can watch the video below to see how easy our installation is, the only tool required is a 13mm socket:
Here is a video of the different gas spring finishes and the system in action:
Redline Tuning has been developing our Hood QuickLIFT systems for over 20 years and have applications for over 350 unique vehicles, check out our website for your vehicle application.
Please contact us for any questions.
UNBROKN
Central Virginia
04 F-350 CC dually, 97 Infiniti QX4, 21 Bronco BD
I have the Redline max lift. I am 5'7". I have NO problem reaching the hood. I love them and would recommend them any day!
BD, no lift, no squatch. Even with lift and tires, I should be able to reach it.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
I have the Redline Maxlift struts because I want the hood as much outta my way as possible. That looks to be about 7' 3-4" measuring straight to the ground. I can reach it (I'm 6' 3") but if you're 5-7" shorter, it'll probably be tough. You can get the non-maxlift ones, and/or do the strap pull down, and should be fine.
