Vehicle Height (With Accessories)
xXChartmanXx
Ford Explorer, Honda Pilot
So, while perusing the Ford site again for the 18,000,000th time. Found that every trim is listed as 73" tall including the WildTrak and FE which come with the Sassy package. Then they list base ground clearance as 8.3" (4 door) and 11.5" with the Sassy. Doing some complicated math it seems like there is 3.2"s of difference in clearance between base and Sassy. Would that directly translate from 73" height to 76.2" in height? Is the hard top going to be any higher than the soft top? Does the high clearance suspension boost the body up any which would not be calculated in ground clearance? I've got 82" clearance into the garage, trying to calculate if the Bronco will make it in with roof racks (2-3" height on top of car).
tritonx100
2020 ford explore
you must have read my mind. I had the same question.
Headsong
And I've been wondering about the 2" lift initially offered? Seemed like 8" isn't enough off road.
