How Do You Display Battery Voltage on Console?
Mscdman
P
Denver
OBX
I’m trying to figure out how some people are getting on their center console on the right hand side a display for gauges where it displays battery voltage. I don’t see this option at all from the center console when I go to vehicle settings how is this brought up?
Ducati1098
Using the RH steering wheel buttons.
Mscdman
P
Denver
OBX
Thanks. The user manual doesn’t show that gauge display is an option. Thank you
dgorsett
colorado
F250, Mustang, Explorer
They call it My View, you get to kinda set up what you want.
Scott R Nelson
Meridian, ID
You can also get there from the off road sub-menu.
I prefer the "gauges" setting which shows four things: boost, oil temp, transmission temp, and voltage.
Mscdman
P
Denver
OBX
Is the gauges setting accesd from the steering wheel up down button?
Scott R Nelson
Meridian, ID
On page 112 of the 2021 Bronco Owner's Manual is a picture of the steering wheel controls on the right side of the wheel. It is all explained there. You press the Menu Button - the one with three parallel lines - to get a list of things you can select. The three that show useful things on the display next to the speedometer are MyView, Trip/Fuel, and Off-Road. The easiest way to get the the one I mentioned with the four values is to go to Off-Road and select Gauges.
You select from the list using the up and down arrows there, and you select things using the OK button between the arrows.
Everybody who owns a Bronco should fool around with all of these different menus to see what they can get.
I initially set MyView for what I thought that I needed, then after using a few setting in Trip/Fuel and Off-Road, realized that I needed to adjust it a bit. Now I can get to everything that I want to see from MyView. But that's because I tried all of them before deciding what was best for me.
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
I keep mine in the off-road section all the time, and then just go up and down to look at either tire pressure or gauges. usually leave it on gauges.
