I bought a set of buckles
I’ll take it apart and see if I can figure it out
Tell me more. I was seriously eyeing that for my truck...if it ever comes.These diy seat deletes are way better than that goose gear trash ,cheaper too.
Reports here of poor quality for the high priceTell me more. I was seriously eyeing that for my truck...if it ever comes.
What are the clips for? No mention on your Build Thread.Tore the buckles apart and started making the base
it will be 12” clearance under
more photos on my build thread
Your last two photos of plastic parts in your hand.what clips?
That’s the electrical connection in both seatbeltsYour last two photos of plastic parts in your hand.
Sorry, had missed the alert earlier as I had been posting a lot. Thank you for the response. But to be clear, you do not own the platform? I am very open to being talked out if it because of the price so I am all about intel on this piece.Reports here of poor quality for the high price
That was my plan as well. Did you get it working?That’s the electrical connection in both seatbelts
I bought a left and right and took them apart to use instead of removing the buckles from the frame
YepThat was my plan as well. Did you get it working?
Is this 2.4 or 240 ohms. hard to tell if the colors areYou need to remove the buckle from the seat and plug it in. There is a perfect pocket made to hide it.
If you remove the belts as I did, you need to install a 2.4ohm resistor into the plug.
Is that 2.4 or 240 ohms. It’s hard to tell if the colors are red, yellow, gold, gold (2.4) or red, yellow, brown, gold (240)You need to remove the buckle from the seat and plug it in. There is a perfect pocket made to hide it.
